It is currently Fri May 15, 2026 11:34 pm
PostPosted: Sat Feb 15, 2014 4:46 pm
Finishing the front brakes now. The rear shoes on either side have three holes topside. Of the three, the middle one is blue with a slightly chamfered edge which seems like the hole they intend for the adjusting guide and one end of the secondary return spring.
The issue I have is that the spring seems looser there and the lower of those three holes produces a stronger spring tension and a tauter cable.
Any issue with using the lowest point instead of the blue middle one for the guide/spring?
Don't know why I felt like asking, but I'd rather not F up my new brakes before I've driven.
PostPosted: Sat Feb 15, 2014 4:50 pm
The cable needs to be tight enough that the adjuster finger is just below center on the star wheel.
