It is currently Tue Dec 30, 2025 9:19 am
 Post subject: Carb rebushing
PostPosted: Tue Feb 11, 2014 1:41 pm
Is some play acceptable? I ask because I know pretty much nothing about carburetion. The 3 Holley 1945 carbs I have all have a little play, some a touch more than the others, but they all have some. All I have to compare is the throttle body on 5.9 magnum V8, which has zero slop.
PostPosted: Tue Feb 11, 2014 2:51 pm
Some play can be compensated by your idle mixture adjustment. If your around 2.5 turns out your fine. It is bad when you have to run it 4 turns out. You may want to have the shaft re-bushed at that point.
PostPosted: Tue Feb 11, 2014 4:20 pm
thank you sir
when I sprayed brake cleaner into the area, the motor stumbled (yes I know not to do that again!)
PostPosted: Thu Feb 13, 2014 7:36 am
It's chlorinated brake clean that's the seriously nasty stuff. "regular" brake clean is merely explosively flammable. Different types are/are not available in different states.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Feb 13, 2014 10:17 am
I went and looked and is was not chlorinated. Dumb luck. :shrug:
I am going to see how many turns my idle mixture is at and go from there. I found a local guy to rebush the carb for $30 if I pull the bottom off and take it to him.
PostPosted: Tue Feb 18, 2014 7:03 am
Well Ted it is around 3 turns, maybe a little less. yay
What should the idle RPM be in D? say sitting at a stoplight.
PostPosted: Thu Feb 20, 2014 11:11 am
On my 74 the sticker shows to set it at 750 rpm out of gear which I do...... and the distributor is set at 10 degrees initial.......which is not per the sticker. I recurved my 3755042 distributor.
Based on that it shows 19" of vacuum cold.
Once warmed up, the tach reads about 650 rpm in gear at a stop light.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
