It is currently Sun May 17, 2026 10:35 am
 Post subject: Brake Line Sizes
PostPosted: Sun Feb 16, 2014 7:04 pm
Im replumbing the brakes on my 51 DeDoto....
Im using a 91-96 Roadmaster master cyl and combination valve.(same as ImpalaSS with rear disc)
Front brakes are 1978 Fury LateB disc ...rears are Ford Explorer disc
The line from the master to the combo valve is larger for the rear brakes. From the modfied combo valve the rear goes to a Wilwood adjustable prop valve and the front goes to a line lock. Both the prop valve and line lock use 1/8" 27 npt fittings .
Can I use 1/4" lines from the valves out? Does the rear have to be 3/16"?
PostPosted: Tue Feb 18, 2014 11:13 am
So long as you can get/make the correct inverted double flare or metric bubble flare as required for your fittings, line nuts, & hoses- then yes. Just make sure that the combi valve stuff IS 1/4". I've had a couple GM's that had 6mm line going to the rear brakes (1/4" wouldn't work).
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Feb 20, 2014 2:21 pm
Car Model: '65 Valiant 170 T5
The difference in brake tube "swell" at max pressure between 1/4" and 3/16" is surprisingly large. I did the math once and was very surprised at the results. Enough surprised that I had another ME check my work and he too was surprised. That "swell" is a difference in volume, which will make the pedal feel 'mushy' to the driver.
None of the aftermarket brake mfg's consider 1/4" viable for brakes, clutches only. That said, I know of several examples of 1/4" used by the OE's. I wouldn't do it or suggest it, go 3/16" if at all possible.
The reason for 1/8" NPT is that fittings in 1/16" NPT aren't terribly common. Can be had for sure, but aren't common.
Thom
Cross-threaded is tighter than Lock-tite
PostPosted: Thu Feb 20, 2014 7:59 pm
Thankyou gentlemen.....We did everything in 3/16 from the combo valve out.
