It is currently Tue May 26, 2026 3:05 pm
 Post subject: A100 shift
PostPosted: Fri Feb 21, 2014 7:12 pm
Car Model: 1968 A108 225/3 on the tree
has anybody seen/heard of/or owned an A with a floor shift instead of the 3 on the tree?
my column is getting real sloppy. to the point where something is blocking me from putting grease in it. the zerc is ok. i took it out and blew grease thru it. something in deeper must be in the way. looking in the cab, the floor rite ahead of the parking brake could be a good spot. i'm thinking of a comically long shift handle like in some semi trucks.
anybody ever try this?
 Post subject: Yep...
PostPosted: Sat Feb 22, 2014 8:04 am
I know that some of the 80's shorty van's came with the A-833OD (shift stick is a little different than what is seen in the trucks or cars).
PostPosted: Sat Feb 22, 2014 1:42 pm
I guess I was a bit unclear in my question. I mean the a100/A108 vans or pick ups. Ever seen Wong of those with a floor shift in place?
PostPosted: Sat Feb 22, 2014 1:49 pm
I have seen them, but i don't believe they were factory. You might want to try asking this over on www.vannin.com If I remember correctly, all the conversions I have seen mounted the shifter back above the trans and used a loooooooooong shifter handle. Usually an aftermarket shifter like a B&M or Sparkomatic or some such.
