It is currently Fri Jan 02, 2026 3:24 pm
 Post subject: Despite warning
PostPosted: Fri Feb 28, 2014 2:50 pm
So despite warning I finagled a deal on some clifford stuff. Will pipe heat into manifold via water jacket in bottom of intake, so no worries there. Also don't mind the ghetto blockoff for vacuum, hadn't bought a new set of caps at the time and wanted to start her up. Screams pretty loud with open headers. Will have to get that resolved next.
Electrical for the chokes has been cleaned up already, new vacuum caps just need to be popped on. Also will re-run the PCV hookup as well.
Is Dual weber 32/36. Haven't gotten to actually drive it yet, only short startups to make sure everything is working before it starts to annoy my neighbors. Sounds pretty fantastic to my ears though.
Next step is waiting for the rain to stop coming down here so I can hook up the lokar kick down and new throttle cable (old one was pretty shredded) and drive it to the exhaust shop near by to have that finished up.
1968 Plymouth Barracuda [Daily Driver]
1972 Dodge Dart Swinger [Lent out as Daily Driver to a friend]
2010 Challenger R/T 6 Speed
PostPosted: Fri Feb 28, 2014 6:45 pm
might want to make a set of down pipes before driving it.....looks great
keep on roddin'
 Post subject: x2
PostPosted: Fri Feb 28, 2014 8:44 pm
Yep after about 3-5 minutes or under acceleration and load your firewall will need a repaint and your wiring harness may need complete replacement (acc cable may need it as well)...if you can't make a down pipe (header collector and flange to a hose clamp and 18" of flex to dump on the pavement, each pipe)...you may need to resort to a tow truck....
If you are going to headers, install a mini starter to finish the look in the engine bay.
PostPosted: Sat Mar 01, 2014 4:41 am
Sweet! Looks pretty cool.
Ditto on the downpipes. Open shorty headers put some serious heat into that engine compartment, especially with any RPMs.
Let us know how it turns out. I love the dual look!
PostPosted: Sat Mar 01, 2014 2:12 pm
If you're going to run it without the downpipe............
Do it at night so you can at least see the flames.
:wink:
 Post subject: Re: x2
PostPosted: Sun Mar 02, 2014 6:13 pm
Fair point, exhaust shop is 1 mile away, mostly down hill so I was just going to baby and risk it, but better safe than sorry. I already have all the collectors and hardware, flex tubes to be gotten tomorrow after work.
Got the new throttle cable hooked up. Wouldn't suggest anyone go cheap and get the Mr Gasket universal one. Its crap. Won't be driving much further than exhaust shop and back with it before I replace with a higher end unit.
PostPosted: Wed Mar 05, 2014 6:53 am
Is that a Clifford intake?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Wed Mar 05, 2014 1:08 pm
Yes it is. Which in itself is just included with repackaged redline stuff(even came with parts in the redline box).
PostPosted: Thu Mar 06, 2014 1:19 am
I've never seen one of those before. Glad things worked out for you.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 9 guests
