It is currently Thu May 28, 2026 5:59 am
Post new topic  Reply to topic  [ 62 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Nov 14, 2013 7:18 am
I will weld a tab on the bottom of the J and tie it in to the sectioned motor mount bracket as its about 1/8 from it now. Dont tie it to a frame support as the motor and turbo still need to move.
I didn' t buy it, I built it.....
 Post subject: weld necessity
PostPosted: Fri Nov 15, 2013 3:51 pm
Junior, where are you located, and can't that flange be bolted to the OEM manifold, using some bolts with tapered heads or studs? I don't see where it should be necessaary to weld it to the cast iron manifold.
Maybe I don't understand something...
Enlighten me, please...
Bill, in Conway (central) Arkansas
1964 Valiant 4-door sedan, 225 turbo/904
 Post subject: Re: weld necessity
PostPosted: Fri Nov 15, 2013 9:45 pm
i am in south jersey. i am going to weld the flanges to their appropriate ends and bolting the pipe to the manifold. i didnt believe that the pipe would be sufficient to support the weight of the turbo by itself and was asking what others have done. when i look at pictures of peoples builds i cant really see anything besides the pipe holding up the turbo but knew it couldnt be so.
PostPosted: Sat Nov 16, 2013 4:47 pm
Junior,
Thanks for the info, and by-the-way, I completely agree with your thinking.... and Charrlie's... it NEEDS some additional support!
Bill
PostPosted: Sat Nov 16, 2013 7:39 pm
no problem man im just trying to get all my ducks in a row before slapping this thing together.
 Post subject: boost is addictive...
PostPosted: Sat Nov 16, 2013 9:26 pm
You're gonna have SUCH fun!!!! :)
Bill
PostPosted: Sat Mar 01, 2014 12:37 pm
Does anyone have any pictures of their j-pipe turbo setup and any bracing they did? I'm trying to find out how I want to mount my Grand National turbo on my slant. Thanks for any and all info!
And from what I've gathered is that the J pipe is bolted to the factory exhaust flange on the manifold and then on the other end its welding on a turbo flange and bolting on the turbo? Yeah that doesnt sound safe at all to do without bracing it to somewhere to the engine...especially with how much I read of the cast manifolds liking to crack! Added weight to the cast manifolds sounds like a no-no without some kind of bracing but I dont know how I would brace the turbo to the engine.
-Brodie
1977 Dodge D100 stepside, slant six/3 on the tree
2002 Chrysler 300M Special (daily driver)
PostPosted: Sat Mar 01, 2014 2:20 pm
Brodie,
This forum is not configured for pictures, but I have several pictures and a schematic of that setup that the designer, PISHTA on "for a bodies only" sent me. If you'll send me a blank email to Billdedman@hotmail.com I will send you those.
Just let me know.
Bill
PostPosted: Sat Mar 01, 2014 8:09 pm
I emailed you earlier. Thanks!
-Brodie
 Post subject: Taken care of, now...
PostPosted: Sat Mar 01, 2014 9:49 pm
Brodie,
Your email went into my junk box, so I didn't find it right away... sorry!
Bill
PostPosted: Wed Mar 05, 2014 9:40 pm
hey billdedman can you send me those pics? ill put slant jpipe in the subject line. ill see if i can post them on here for everyone to see.
PostPosted: Wed Mar 05, 2014 10:40 pm
Junior; I sent them to you, but this forum does not have graphic (picture) capability.
You'd have to post them on a different web page and post the URL here.
They should be in your mailbox.
Bill, in central Arkansas
PostPosted: Thu Mar 06, 2014 12:09 am
cool thank you. ill send them to my photobucket account and upload them that way.
PostPosted: Thu Mar 06, 2014 12:36 am
these are all the pictures i could find pertaining to j-pipes. they are all phishta's pictures as far as i know. if anyone else has pics of their jpipe setup feel free to post them.
PostPosted: Thu Mar 06, 2014 11:02 am
That's cool! Nice job, Junior!!! :)
