It is currently Fri Nov 20, 2026 8:26 pm
PostPosted: Mon Mar 03, 2014 9:36 am
Has anyone ever replaced the gear selector shaft seal(s) on a 904 IN the car before? My auto is perfectly dry except for that dang seal leaking oil at rest. It is only getting worse. I hate to pull the valve body down, but it is looking like I have no choice. I did not know if there was a tool or a way to do it in car with little parts removal besides the linkage.
Joe
1966 Plymouth Barracuda
1972 Dodge Demon 340
2012 Dodge Ram 3500 6.7 Diesel
PostPosted: Sun Mar 16, 2014 11:26 am
You could try to pull the linkage and use a aul to remove the seal. The hard part is to get the new seal in. Drop the rear crossmember and you may have some room to work. :cry:
I know guys that do it this way. But for me I pull the pan and remove the valve body, remove the seal and with a homemade tool install the seal drawing it down as even as I can. Those pesky seals just can't deal with the flood of fluid when the converter drains down from sitting.
