It is currently Thu May 21, 2026 5:24 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 26, 2014 10:41 am
Car Model: 87 B150, 1970 Valiant 4-door
Well, I'm going to take them back off in May or so.
I have to assume they are done salting the roads for the year.
I'm going to goop everything up w/antiseize per Dad Truck's suggestion and see what happens.
Another question I have is this:
The perch (not sure if that is the word) that the front eye bolt attaches to is riveted to the 'frame'--it's a unibody, so I'm not sure the word applies--has a 3/16 steel plate shaped like Texas/a bent home plate sandwiched between it and the 'frame.'
On the driver side that plate is rotten. The 'perch' and 'frame' are fine.
I'm entertaining grinding off/driving out the rivets, reverse-engineer a new plate by mirroring the non-rotten passenger side one, grinding off the old plate, abate all rust, paint frame, weld on the new plate, bolt on perch by cutting a hole in the floor to access interior of frame, welding the nuts to the bolts and welding a patch over the hole in the floor, abate all other rust and paint everything under the van and inside the floor hole.
Should this work, or do I need to address it differently?
