It is currently Thu Nov 26, 2026 6:51 am
PostPosted: Wed Mar 26, 2014 12:42 pm
Sneaky! Is the stock cam spec "advertized" or at .050? Thanks.
Sam
PostPosted: Wed Mar 26, 2014 2:13 pm
Sam
Advertised.
PostPosted: Wed Mar 26, 2014 4:01 pm
185 RWHP is not so tough on pump premium. Lots of builds here to do that. That is a small cam, not much above stock, for what you are trying to achieve. I would recommend something like the 234/228 @0.050" 106 LSA Oregon cam installed at 100 deg c'line, and with a mild/medium upgrade in stall speed. Headwork is the biggest factor of all, so if you don't get it with a cam/carb change, then go back to the head. Huge gains possible there.
PostPosted: Wed Mar 26, 2014 4:02 pm
Also, what exhaust system used, after the headers?
PostPosted: Wed Mar 26, 2014 5:41 pm
Lou,
I know awhile back he had engine temperature problems and I asked what he was running for mufflers. I think Sam was just running super turbo type Walkers. They really don't help scavenge the exhaust or help reduce engine temps.
PostPosted: Wed Mar 26, 2014 9:52 pm
Don't use the Offenhauser, spend the money for a Clifford. There is a noticeable difference between the two, with the advantage to the Clifford.
When using a 2v carb, the Offenhauser is not much better then a standard SuperSix manifold.
PostPosted: Thu Mar 27, 2014 10:15 am
Car Model: Road Runner
After the shorties, y'd into a 2.5" back to a Flowmaster Delta flow. 2.25" after the Flowmaster, all the way out the back. Used to have a glasspack setup as a side pipe, wife says she liked the glasspack, as it was more "rowdy".
Thanks for the Cam suggestion, I know the Comp wasn't that spectacular, seems like it's barely better than stock with terrible idle, but it was chosen as the Erson cam I had was smacking the retainers on the vavle guides under high RPM. The Comp was the quickest thing I could get at the time.
We got the Offy for $100.00, so it was hard to turn down.
PostPosted: Thu Mar 27, 2014 11:21 pm
Offy better down low, but will definitely make less HP. Exhaust should be OK, but might have moderate restriction for that build. If you used a flowmaster or similar Y near the trans Xmember, then that's OK. If you have a cobbled junky Y, or too far forward, that can cost you bigtime on HP (10-20) - been there...
PostPosted: Sat Mar 29, 2014 5:35 pm
Dan, have you considered raising that rear end gear ratio?
Question: how much do you have to remove to get 9:1 compression?
When you added the cam, how did that affect the feel and performance?
Thanks, Craig
PostPosted: Sat Mar 29, 2014 10:41 pm
Dan-O,
I,ve got some pinging with my combo as well. Comp 264s cam, 9.87:1 comp, stock two barrel intake & carter carb, 1.7 & 1.44 valves and pocket ported heads and stock ignition. I'm having to retard the ignition a little and be careful with my right foot so I can stave off the pinging. I'm going to source a Erson 280/270 cam or/and get one ground locally. It's so frustrating having the wrong cam in the car.
I have a whole suit of things to do (intake, ignition, carby, cam, etc.) if I coild only find the time...
Bare Metal Maz
Love cruising in a bare metal Val!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
