It is currently Mon May 18, 2026 3:00 pm
PostPosted: Wed Mar 26, 2014 5:47 pm
looking for opinions.
Install the offset upper control arm bushings or
something like QA1 "Camber Bolt Adjusters"?
http://www.qa1.net/qa1_motorsports/drag ... sters.html
What do you think?
Street Car, some drag, but no road racer.
PostPosted: Wed Mar 26, 2014 8:47 pm
Those are just replacement cam bolts. They won't give you any more adjustment than stock. If you need or want more negative cambet or positive caster you need offset bushings or different control arms.
 Post subject: bolts
PostPosted: Thu Mar 27, 2014 6:24 pm
thank joshua, they make it sound like you get additional travel with bolts.
PostPosted: Thu Mar 27, 2014 11:23 pm
2nd Josh's statement. Gotta love that slippery marketing language...
PostPosted: Fri Mar 28, 2014 6:22 am
With MOOG bolts you get 1 1/8 (+-), so if QA1 gets 2.5(+-), thats alittle better.
1964 Dart GT
PostPosted: Fri Mar 28, 2014 7:49 am
The cam bolts can't travel any farther than the slots in the chassis.
PostPosted: Fri Mar 28, 2014 9:22 am
so are they only meant to be used with the Moog Eccentric Bushing Kit ? :?
1964 Dart GT
PostPosted: Fri Mar 28, 2014 10:29 am
No, it means that they can't do anything that the stock cam bolts don't do already.
PostPosted: Fri Mar 28, 2014 12:08 pm
I'm total confused, aren't these measurement measured off the center axis of the bolt. :?
1964 Dart GT
PostPosted: Tue Apr 01, 2014 12:04 pm
The slot that the camber/caster bolt slides in when its eccentric is rotated can only travel as far as the width of the slot regardless of how offset the eccentric is. If one were to install Moog problem solver eccentric bushings correctly the range of adjustment will be increased to provide additional caster. These offset bushings relocate the upper control arm’s axis for additional plus caster adjustment.
PostPosted: Tue Apr 01, 2014 2:08 pm
after looking at the bolts alittle closer :shock: I have a fair understanding, but until I get into the frontend rebuild I am still mystified by mopar suspension/adjustments. I still like Slants! (the rest of the mopar mystique eludes me.)
1964 Dart GT
PostPosted: Wed Apr 02, 2014 2:48 pm
So are 95% of alignment jockeys found under America’s frontend alignment racks, and that’s the point, Mopar has adjustments unlike today’s junk with huge sloppy rubber bushings and only camber adjustment.
PostPosted: Fri Apr 04, 2014 7:01 am
Once you get up under there, it's pretty easy to figure out. The upper control arm (UCA) mounting bolts sit in slots on the frame, so that they can slide in and out to change the position of the UCA. Their position is controlled by those big eccentric washers, which push against little rails on either side. The washers are locked from rotating on the bolts, so turning the bolts also turns the washers.
If you want more negative camber, turn both bolts in such a way that the UCA is pulled in toward the center of the car. If you want more positive caster, you want the upper ball joint to move backward. So turn the rear adjusting bolt so that it pulls the back of the UCA in, and/or turn the front bolt so that it pushes the front of the UCA out.
The MOOG offset bushings don't increase the range of adjustment, but they do offset the range of adjustment depending on how they're installed. If you install them with the holes closer to the ball joint, you're effectively shortening the UCA and shifting your range of adjustment towards more negative camber.
Escape Velocity Racing
PostPosted: Thu Apr 17, 2014 4:57 pm
And, if I understand correctly, maximum positive caster (with stock control arms) can be achieved by using offset bushings front and rear and doing both. Right??
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Thu Apr 17, 2014 5:25 pm
not using standard arms.
and I bought a set of the QA1 Camber Bolts and they are a bit stouter than the stock or Moog.(Nuts,Bolt & washers)
1964 Dart GT
