It is currently Fri Nov 27, 2026 8:34 am
PostPosted: Wed Apr 02, 2014 6:57 am
Can't be normal is it?
PostPosted: Wed Apr 02, 2014 8:34 am
Yes, if the cam chain is worn, or you have a distributor problem such as broken or missing springs on the advance mech. I assume this is with the vacuum advance disconnected. If not you can add that to the list of possibilities. Less likely is a slipping damper.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Wed Apr 02, 2014 8:40 am
thanks
yes advance is disconnected
the distributor is a new 'reman' and the old one did it too
Looking like timing set replacement and maybe a new damper I guess.
How big of a job is the timing set?
PostPosted: Wed Apr 02, 2014 11:13 am
Does the engine idle smoothly?
A choppy idle can make the mark jump around.
PostPosted: Wed Apr 23, 2014 10:50 am
Timing set isn't particularly difficult to do. If you are so inclined, a quick search on the board will net you the step by step instructions (with pictures!) on how to do the replacement. :D
I wouldn't worry about replacing the damper just yet. I recommend getting an answer to Doc's question above, and go from there.
~THOR~
PostPosted: Thu Apr 24, 2014 9:49 am
Thanks, I am still trying to answer Doc's question.
