It is currently Thu Nov 26, 2026 4:20 pm
 Post subject: Manifold heat valve
PostPosted: Fri Apr 04, 2014 12:39 pm
I was out puttering around on the Dart today, putting new motor mounts in, changing the oil, etc., and I noticed the manifold heat valve was frozen.
I got it loose, but it's far from "free." Does anyone know which direction is open on one of these? Until it's totally free, I want to make sure it's letting the exhaust straight out.
Thanks!
Oh yeah, this is on a '65 170.
1965 Dodge Dart 170 Wagon
1965 Ford Mustang
1965 Buick Skylark Hardtop
1965 Chevy Corvair Monza Convert.
1953 Buick Special Riviera
PostPosted: Fri Apr 04, 2014 12:49 pm
The top edge lays toward the block the bottom edge towards the wheel so clockwise will open counter to close.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Fri Apr 04, 2014 1:18 pm
Great! Thanks! It looks like it was frozen shut.
1965 Ford Mustang
PostPosted: Fri Apr 04, 2014 7:13 pm
Just to make sure I'm thinking straight here...if I rotate it counterclockwise, all exhaust is going out the pipe, and not being diverted up to the carb. Is that right?
1965 Ford Mustang
PostPosted: Fri Apr 04, 2014 8:27 pm
6 Pack Dart
Been a while since I have looked , but I think that sounds backwards.
Richard
PostPosted: Sat Apr 05, 2014 7:47 am
Closing causes the exhaust to exit through the exhaust pipe opening allows the exhaust to circulate between the exhaust pipe and to heat the carburetor. Once the area heats up the exhaust "Valve" will close directing all exhaust out.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
