It is currently Fri Nov 27, 2026 3:10 am
PostPosted: Thu Apr 10, 2014 7:43 am
The BBD was rebuilt 10+ years ago and mounted to the intake. And there is sat and rusted.
I started to take it apart in order to make sure it was still clean and remove all of the rust.
I broke the screw shown below:
(Photo borrowed from another post. Did not have time to upload my photos last night)
I cannot find it listed as a carburetor part.
Are they available and where would I get one. Or an acceptable replacement
Thanks
Dennis
1975 Dodge D100 Utiline
Slant 6, Super Six, Weber 38, 727
Repair work in progress. :)
PostPosted: Thu Apr 10, 2014 7:59 am
fast idle adjustment screw. you should be able to find one in the help section at your local auto parts store
PostPosted: Thu Apr 10, 2014 12:02 pm
or hardware store.
PostPosted: Thu Apr 10, 2014 1:22 pm
If you cannot find one, I probably have one in a bunch of parts I bought. PM your address if you need it.
1964 Dart GT
PostPosted: Fri Apr 11, 2014 6:37 am
Well, the adventures continue.
Cannot find the FIRST screw I broke. Going to hit up the junk yards for a replacement. Hopefully.
And now I broke off an idle adjustment screw in the throttle plate. I drilled and re-tapped, but now I wonder if it will still work properly
I would love to throw a new carb on, but I have already exceeded my budget.
PostPosted: Fri Apr 11, 2014 8:40 am
where you at?
PostPosted: Fri Apr 11, 2014 8:44 am
or hardware store.
+1. How is it you keep breaking screws? Sounds like you need to soak it all in tsome penetrating lubricant and maybe even clean the threads up with a wire bruch.
PostPosted: Fri Apr 11, 2014 8:56 am
Thanks for the replies.
I will check my local hardware store
The carb was rebuilt and never run. It sat uncovered for 10+ years.
I did soak the screws with penetrating oil.
The fast idle screw just snapped. Like it was already broke. It did not take any real effort.
The idle mixture screws was coming out. Slowly. And then pop.
When I got the other screw out it appears to have been bent at one point.
I am in the South Suburbs of Chicago
PostPosted: Fri Apr 11, 2014 9:44 am
that sucks. if you were closer i would offer you a carb you can use for parts.
PostPosted: Mon Apr 14, 2014 10:59 am
Update time.
Found the fast idle screws off of a BBD on a jeep at the parts yard.
Throttle plate on that carb was different than the one I have. Plus there was too much electronics and crap in the way for me to get the whole unit out in the time I had.
I will have to order the idle adjusting screws from somewhere. Walker products has them but shipping is expensive.
Any other recommendations?
 Post subject: drill and tap
PostPosted: Tue Apr 15, 2014 10:05 am
You might want to drill them out and retap the arm with a fine thread tap of common thread size, so you can use a readily available machine screw of that thread size and adapt (round, file, grind, polish) the end of the screw (if necessary) to fit the spot where it makes contact with the carb.
I lost my fast idle adjust screw for my Weber and couldn't find a replacement for the life of me. I did the above. I used #10-32 thread, but there are finer threaded taps/screws as well. Carb adjustment screws are pretty fine thread pitch (for max adjustment).
brian
PostPosted: Tue Apr 15, 2014 1:13 pm
Update time.
Try this guy for the screws http://www.carburetor-parts.com/Idle-Mi ... c_664.html
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Tue Apr 15, 2014 2:53 pm
Update time.
Dave
Thanks. I will check it out. Have to measure the screws when I get home.
PostPosted: Wed Apr 16, 2014 6:11 pm
With rusted/corroded in place screws, soak 'em well with penetrant and let 'em sit overnight, then soak 'em again! When ya start to remove the screws just barely turn them in one direction, then STOP.
Turn them back the other way 'til they start to bind. Clean the threads with a fine wire brush and repeat the above 'til they start to bind again - STOP. Go back and forth like that without putting any strong effort
but go just a bit further each time. Adding heat with a bic lighter or soldering gun may also help.
It seems that you've already discovered that trying to rush creates more delays, the same way most of us have.
BC
Users browsing this forum: Google [Bot] and 29 guests
