It is currently Wed May 20, 2026 12:28 pm
PostPosted: Sat Apr 12, 2014 3:16 pm
Putting on the new top. I see the gutter where the top is attached, but am wondering where the water is supposed to finally exit the quarter panel. Is there a drain that needs to be cleared?
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Sun Apr 13, 2014 9:28 am
My Dart just drips from the gutter down to base of quarter between wheel and door.
PostPosted: Tue Apr 15, 2014 4:27 pm
The factory also had small "drains" with tubes, installed at the bottom of the well liner, and the tubes lead into the q-panels.
PostPosted: Wed Apr 16, 2014 4:47 pm
Yeah Doc is correct (again) BUT, check your well liner.
When I got my '63 I was puzzled as to where the water would go.
Found out thru FABO, but when I checked my for drain tubes they weren't there.
Maybe that's why I had to weld in new rear floors??? lol
Gary from Downunder
2 weeks ago I couldn't even spell mukanic - now I are one!
PostPosted: Mon Apr 21, 2014 1:02 pm
This thing is mostly patches, born in New Hampshire. I'm vacuuming out a lot of sand from the quarter panels, and thinking of a hail Mary shot of rust converter before I move on with the top. The well liner might need some fixing up too.
