It is currently Fri Nov 27, 2026 5:21 am
 Post subject: what oil for the sw
PostPosted: Thu Apr 17, 2014 9:53 am
Hello, I am in the process of changing my oil pump and bought some 10w30 for it. But iu am curious as it geta closer to the hotter months shiuld I run a straight sae30? Any input would be appreciated. This is on a 81 d150. Everything is stock still. Not sure of the actual mileage but it runs well. It's just that the oil pressure as been dropping when I stop and idle at a light in gear. But If I put it in neutral and thw the idle goes up and the . Oil pressure will rise to almost 30psi. So I figured it's time for a new pump
PostPosted: Thu Apr 17, 2014 9:56 am
Honestly, with all the issues people are having with new oil pumps I would leave the stock one in there if there were as little as 5psi hot at idle.
PostPosted: Thu Apr 17, 2014 10:11 am
Ditto what Josh said, and run 5W-30, synthetic if you can afford it.
PostPosted: Thu Apr 17, 2014 10:40 am
Maybe I'll give that a whirl. Im sure I can return the oil pump and just buy some good 5w30. Thanks
PostPosted: Thu Apr 17, 2014 2:07 pm
I'd stick with 10w30 that has a large acceptable summer temperature operating range. 5w30 is more for sub zero weather. The first number is cold viscosity 10 being thin and easier to turn over, and the second number is operating temperature viscosity.
Perhaps shimming pressure relief spring will give better low rpm oil pressure, or just cleaning the little cylinder in the relief valve to keep it from sticking open at low rpm would help increase low rpm pressure.
PostPosted: Sat Apr 19, 2014 7:22 pm
Pressure sender OK? What filter you have on it?
Rotella semi synthetic 10-30 is nice. Has lots of detergents because it is a diesel oil.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot] and 6 guests
