It is currently Fri Nov 27, 2026 6:57 pm
 Post subject: possibly burning oil
PostPosted: Thu Apr 17, 2014 10:19 am
OK I'm installing a 225 in a 53 and me and my wife fired up the engine the other day with no problems turned on right away I heard a ticking noise till it warmed up then event away I figured it was cause its been sitting for a long time. After running it a while I checked out the pluggs and noticed all but one of them had adapters and the one without a adapter was the only good one the others were burned up pretty bad. Can I get some info on why they used these adapters. Cool it be from oil burning.
PostPosted: Thu Apr 17, 2014 2:15 pm
Little info in your post, I don't think I can help you too much. I guess "Adapters" are towers? Is your slant built between 1964 to 1974? (then it will have spark plug tubes). Pls check:
http://www.allpar.com/fix/spark-plug-tubes.html
About the oil and spark plug fouling you might try to run a hotter spark plug to avoid fouling (depending on how much oil is passing trough), try an NGK #4, with no tower, so the electric losses are lower, and the spark stronger (don't remember the ones I'm using now in a 1969 engine, and I better won't tell you until you know when the engine was build). Also check the appropriate spark plug for your application, and how much oil is the engine eating/burning with time.
BTW, I hope you changed oil and oil filter before starting the engine...
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
PostPosted: Thu Apr 17, 2014 2:59 pm
I think there called non foulers that screw onto the plugs. The engine is a 1978 225 out of a d100. The oil is full and the engine is running champion spark pluggs
PostPosted: Thu Apr 17, 2014 3:58 pm
Ok , so you have the newer head. Spark plugs need to be installed with their washers, and at 10 lbf torque.
I have no experience with a heavily worn /6, but I guess that if it is too damaged nothing can be done but rebuilding it/swap it, but in the other side you hear stories about how these things run forever and burning oil like crazy without that stopping them (even that for many reasons you should have it fixed anyway); but if you want to give it a try, use the NGK UR4 plugs (the same Aggressive Ted is using), with no towers. See:
http://www.slantsix.org/forum/viewtopic ... 4f9dc369ec
and see how it goes. Of course, do some carb work (clean it, new carb kit, get sure the float level is right and the carb ok, so you're not flooding the poor thing with gas. I guess it should have a Holley 1945; mine has a Holley 1920). I hope somebody else can give you a better guidance; good luck
/6 Dodge Charger 69
PostPosted: Thu Apr 17, 2014 5:53 pm
Just to clarify: I'm suggesting this just to see if hotter spark plugs with better electric flow can handle the oil without fouling too much. Having the carb calibrated will help getting lean burning conditions, so there is more chance to burn the oil.
/6 Dodge Charger 69
PostPosted: Thu Apr 17, 2014 7:38 pm
The late heads (without spark plug tubes) do NOT use gasketed spark plugs! They use tapered seat plugs. Other than that I agree with the advice. (I do not know the # for ngk taper seat plugs for the /6)
Dave
1972 d-100 parts truck
 Post subject: Experience...
PostPosted: Thu Apr 17, 2014 8:01 pm
I had a "road oiler" 1976 slant six that would foul the plugs due to oil bypassing the rings. Instead of going to a set of anti-foulers, I used a hotter plug as you had thought (have used both AC Delco and NGK), the plugs still fouled but instead of being a sticky black mess they were a ashy carbon mess...(NGK UR4 will be hotter than stock in the 1975-1987 BL heads...I think AC Delco can go about one more shade hotter with the RT-43's).
Note that with oil in the chambers you may experience pinging compared to 'normal' combustion...using a hotter plug can also promote this as well as it burns the mix a little quicker...so you may need to adjust your carb or timing if it cleans up your fouling problem...in the long run consider getting a rehone and rering or rebuild instead of a temporary solution that may leave you stranded one day if one cylinder drops out.
2 cents,
PostPosted: Sun Apr 27, 2014 5:23 am
I am using a slightly hotter then normal champion plug. I have always liked champion as they have never "let me down" that being said they are defiantly not performance by any stretch of the imagination. the truck had champion RV14YC's and i replaced with RV17YC's. the old ones were well used and almost worn down to the porcelain. Looks like they were properly gaped periodically. I am running a 1980 with no tubes.
