It is currently Fri Nov 27, 2026 4:59 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Fri Apr 18, 2014 1:04 pm
No.
PostPosted: Fri Apr 18, 2014 1:13 pm
ok wasnt sure. thank you.
still have no idea what is going on.
PostPosted: Fri Apr 18, 2014 2:22 pm
is there any adjustment for the idle circuit besides the mix screws?
PostPosted: Fri Apr 18, 2014 3:14 pm
Not without modifying the metering block.
PostPosted: Fri Apr 18, 2014 4:54 pm
i just went through my holley book and found the same thing. i think im just gonna sell my 650dp and my 390 and get a 600 unless i can figure something out soon.
PostPosted: Fri Apr 18, 2014 4:59 pm
i also rtv'd the intake to head gasket so there are no vacuum leaks. that leaves just the carb now. ive been through the carb more then a few times now. everything is clean and doing what its supposed to.
PostPosted: Fri Apr 18, 2014 5:16 pm
one more try. how would i tell what base plate to main body gasket im supposed to use? when i rebuilt this car i matched the one that was in the carb to one from the kit. i got this carb for a deal so there is no guarantee that it was right to begin with. there has to be a way to figure this out.
PostPosted: Sat Apr 19, 2014 1:21 pm
figured it out. it was the main body to base plate gasket. when i rebuilt the carb i matched the one i took out with one from the kit. anyway its running now. acting like its supposed to. idles fine, flat spot off of idle.
