It is currently Sat Nov 21, 2026 11:29 am
 Post subject: Gear Ratio
PostPosted: Thu Apr 17, 2014 8:23 pm
Now that I have invested in a 8.25 axle, I need to make a final decision on which ring and pinion set to put in it. My leaning is toward a 3.55. My car is a Volare, will have a semi-lopey cam, headers and 4bbl. I have run both 3.90 and 3.55 in a Plymouth Satellite and the 3.55 seemed the perfect ratio for the combination of practical and fun. But that car had a built 360, not a /6. Should I stick with the 3.55 idea or go for 3.31 ? What would a 3.73 be like?
PostPosted: Fri Apr 18, 2014 6:24 am
where / how are you planning in driving it????
PostPosted: Fri Apr 18, 2014 6:41 am
Mostly for fun, street meets, occasionally to work, drag race twice a year and as a backup car. Probably will never be my primary source of transportation...but you never know, right?
PostPosted: Fri Apr 18, 2014 8:03 am
Which transmission?
 Post subject: Lol...
PostPosted: Fri Apr 18, 2014 4:24 pm
Which transmission?
A904
3.55 would be a good compromise for the 'fun'/not daily driver vehicle...a highway run with anything more on typical 205/70R14's would not be fun...although if it were going to be all race car the 3.91's would be good (and with an OD transmission would be very streetable).
If this were a primary driver then 3.21 would be the choice with the build....3.55 will bring the rpm up to meet the cam choice and help get the fat F-body off the line more positively...but may limit your mpg somewhat
so precludes it as the year round mileage getter.
PostPosted: Fri Apr 18, 2014 4:57 pm
So totally do not care about gas mileage. I would put dual quads on it if I thought it would work. 8)
PostPosted: Fri Apr 18, 2014 6:02 pm
What's the issue with tire size, DI? Would certainly like to run something bigger than 205s. Hoping for 275/60/15s on the back. How does this effect my decision?
PostPosted: Fri Apr 18, 2014 7:43 pm
Let's see a "stocker" improvement size tire is about 25.3"
I run a set of 275/50R15's as drag radials with 6 leaf leaf springs and if I have any sag in the springs I wouldn't be able to run the outer lip on the duster rear wheel well is just an inch or so from the edge of the tire.
Those are 25.71"
The 275/60R15 is a 27.99" tire....you might want to see if you can 'fit' one in there before you go changing the ratio and are stuck with it.
3.55's with the 205's put you about 3068rpm at 65mph
3.55's with the 275/50R15 would be at 3000 rpm at 65
3.55's with the 275/60R15 would put you down to 2769 rpm at 65 mph.
This would bring you to the same rpm at 65 mph if you had 3.21's and a set of 205/70R14's on the car...so wit the taller tire, you'll be in the same rpm range, but you may be slower to launch at the lower rpm (us clutch guys just rev up the clock and let go of the "boom" pedal to over come this issue.
The funny part here is a set of 3.91's (favorite slant six drag ratio) would be about 3055 rpm at 65 mph with the 275/60R15...which is splitting hairs from the 3.55's and the "stock" tires.
Since it's a fun car, the 'drone' of the exhaust system will not have to be endured for long on the highway at 3K rpm, headers won't help the quiet there.
I would check the fit first to see if it's do-able, having to jack the back of the car up with block or air shocks to make them fit are going to kill your cornering.
:wink:
Digest that a bit and do some measuring before exploiting the data.
:lol:
PostPosted: Fri Apr 18, 2014 8:12 pm
I actually got that tire size from another Volare that is running 15X8 magnum rims on the back. It'll fit. Droning of loud exhaust is like music to me! I'm an old school hot rodder...with half the hearing I used to have!
PostPosted: Fri Apr 18, 2014 8:40 pm
If your "old school" run the 3.55's. I do, but then I thought 4.56's weren't bad for a freeway gear 30 years ago. That would be 3000 rpms at 55 mph with p295x50x15 tires.
These young ones think you need overdrive for anything over 3.21.
PostPosted: Sat Apr 19, 2014 10:51 am
I found drone sweet spot on modified engine with headers to be about 2400 to 2700 rpm which translates to 40 to 55 mph with 3.55:1 rear and P205/70 14 tires; 3000 rpm = 60 mph which was surprisingly quiet. All of Maine's speed limits on the open road are 45 to 55 mph excepting interstate, and I would stuff foam hearing protection into my ears on any trip exceeding an hour because of the drone. Oh, I had a pair of burned out turbo mufflers at the time. I could not enjoy the car with the head rattling racket, and Truman was president when I was born, so I'm north of stewing rooster tending to old goat status...
Noise abatement was achieved when stock mufflers and 12â€￾ HP-2 by Flowmaster were fitted; hearing protection is now only needed while mowing four acres of lawn with a 50â€￾ 23 hp zero turn.
That said, my cam dictates nothing taller than 3.55 gears as engine’s power band is 3300 to 6000 rpm, and I now find after driving modern overdrive equipped cars 3000 rpm to be a bit busy on a long ride. I use the car for grocery getting, and car shows during warm weather. Short trips not bad, but 4 or 5 hours of buzzing windshield time going to a car show is all I want to deal with.
PostPosted: Sun Apr 20, 2014 5:26 am
WJAJR, that is interesting. I did not know your HP-2's were ahead of stock mufflers. I assumed low restriction turbo jobs of some kind. I have always contended the boom gets set up as a standing wave in the rear exhaust pipe behind the muffler on these cars. It only comes into play when you put a pipe on larger than the stock 1 3/4" pipe. I never was bothered by the highway boom until I went up in size on that pipe. For this reason I have concluded that Mopar went with the smaller pipe for noise abatement, and not for penny pinching on a budget, entry level product.
So the question is, do you think the stock mufflers hurt your gas mileage in any way? Does the restriction in flow of a stock muffler cost anything at the gas pump. If there is a consensus that turbo mufflers add little if anything in the way of performance or economy, I may just spring for stock mufflers here.
Of course this is a two edged sword. I love the low rumble my turbo mufflers produce at anything below 2400 rpm, and backing into a space at a car show, it is nice to hear. But on the road it does get tiresome. And keep in mind, I am a piano tuner who must try and protect what hearing I have left.
Sam
PostPosted: Sun Apr 20, 2014 7:50 am
What? What… Sam, come again…. Speak up and talk sloooooowly.
I have no idea. Three cylinders dump into a two inch pipe times two, 2â€￾ duels all the way back in other words. How much back pressure could there be compared to stock piping? Stock single cross section area = 3.14 x .75â€￾ x .75â€￾ = 1.74 sq inch. Double two inch pipe’s cross sectional area = 2(3.14 x 1â€￾ x 1â€￾) = 6.28 sq. inch.
I don’t check fuel mileage very often, but last summer after a lot of tuning on the old Holley 390 I did check a few times on long distant car show trips where most of a tank of fuel was burned each time, and it came out to 18 -18.5 mpg. I can live with this number, it is better than what I could get with my first Dart three on the tree 273 2v I had in early seventies during the gas line days. By the way the current /6 car is much faster than the 273 car was.
From what I have read regarding tail pipe diameter reduction down stream of muffler is to keep the cooled exhaust gas velocity up. As exhaust gas passes through a muffler it cools when entering that large can, its volume reduces, cools than passes to tail pipe where if pipe is the same size it slows down. That is the theory, but I have another theory; Chrysler could save a buck on a smaller pipe and that was governing design criteria of the day, not performance. That and five bucks will getjah a Starbucks hot beverage. LOL
