It is currently Sat Nov 28, 2026 10:52 am
PostPosted: Sat Apr 19, 2014 2:51 pm
Changing the rear diff fluid. Pull the cover and notice it has got a dent. Start to clean it and find a crack. Now I need to order a new cover.
Then I decide that I Can get the exhaust manifold cleaned and ready for painting. And what do I find but a crack.
Should I , or can i, get the manifold welded? Or start shopping for a new one? I have a set of headers but really was not planning on doing it until the fall.
Photos at https://plus.google.com/photos/10385911 ... 2486431297
1975 Dodge D100 Utiline
Slant 6, Super Six, Weber 38, 727
Repair work in progress. :)
PostPosted: Sat Apr 19, 2014 3:10 pm
I sure do like the looks of your truck
PostPosted: Sat Apr 19, 2014 3:31 pm
You probably need to just mail me your truck. That would solve all of your cracking problems.
Seriously, you can weld the differential cover, unless you want to order a snazzy chrome one.
The exhaust manifold can be brazed by someone who knows what they are doing. Drill a hole on each end of the crack, grind the crack really clean, pre-heat the manifold, cross your fingers, and braze while the manifold is hot. Then place it under some welding blankets of over hot pads and let it cool (or bury it in a bucket of sand and let it cool). If you are llucky the braze will hold.
PostPosted: Sat Apr 19, 2014 3:36 pm
A good experienced machine shop should be able to repair that manifold for you no problem. Same with the diff cover, I actually found one local to me that repaired the oil pan on mine after it got smashed in and cracked.
Its amazing what some people can do with the right amount of skill, dedication, and experience!
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
 Post subject: Yep...
PostPosted: Sat Apr 19, 2014 3:47 pm
You can have the exhaust manifold repaired or replaced, whatever is your fancy, or better on the wallet.
8 1/4" rear diff covers are a dime a dozen, you can get a replacement for cheap the local junkyard, or can order a new snazzy chrome one after market, or just have a buddy weld up the ding and call it good.
PostPosted: Tue Apr 22, 2014 10:59 am
Well its a no go on the manifold repair. Went to two different shops and heard the same thing. Too much carbon on the surface so they wont touch them. And the second shop pointed out a few other potential stress cracks.
So now I have to put the project on hold until I can get the funds to replace the manifold.
I may install the headers I have just so my daughter can drive her pickup to school once before she graduates.
PostPosted: Sat May 03, 2014 7:47 pm
The manifold can be easily gas welded using cast iron filler. I would use my Henrob/Cobra torch and 1/4x1/4 cast iron rod, with appropriate flux. As an alternate, old cast iron piston rings can be used as filler. Your welding shops likely want to arc weld it using nickel electrode, which I would not advise. Maybe you could take the manifold to a car or model engineering show and have one of the Henrob/Cobra vendors do a demo repair for you.
The differential cover can be straightened and patches welded over the cracks.
Ken
PostPosted: Sun May 04, 2014 12:52 am
I might have a decent manifold down at the shop. If I do you can have it.
Will probably go down there next Saturday. I will check.
PostPosted: Sun May 04, 2014 6:01 am
Thanks. That's awesome.
PM me with details.
I live in the south suburbs and work in the western suburbs.
PostPosted: Sun May 04, 2014 7:29 am
We've met before. You got some parts from me when I lived in Lyons.
I am in Park Forest now, just southwest of you a little. I am at Sauk Trail and Western. :D
PostPosted: Mon May 05, 2014 1:45 pm
I thought that was you. Going to finally put the 2 barrel intake I bought from you to good use.
I am at 183rd & Governors Hwy.
