It is currently Sat Nov 21, 2026 4:05 pm
PostPosted: Sat Apr 19, 2014 5:04 pm
Guys,
My 1970 D100 has a 727 transmission. I want a manual trans with floor shifter but don't want to go through the trouble to convert. So I was thinking that a manual valve body with a floor shifter is the next best thing.
I want to use a lokar type floor shifter for trucks. Will this work with the manual valve body? Do you have to push the button to shift? Most I see have a hurst type shifter for racing. I think the hurst shifter would be too short for my truck.
What is the best shifter for this?
Thanks, Craig
PostPosted: Sat Apr 19, 2014 7:35 pm
Check the height on a B&M Z-Gate I have seen them in vans.
PostPosted: Sat Apr 19, 2014 7:50 pm
Some of the aftermarket shifters manufacturers have "truck" versions of their popular shifters.
http://www.ebay.com/itm/B-m-Truck-Autom ... fc&vxp=mtr
 Post subject: Column sleeve
PostPosted: Sun Apr 20, 2014 8:57 am
Thanks for the input. That gives me an idea. With those shifters being cable shifters, I could fabricate a stand to mount the shifter on to get it high enough to be comfortable.
Any ideas on where to get a column manual sleeve to delete the column shifter?
Thanks, Craig
PostPosted: Sun Apr 20, 2014 9:17 am
Most guys just replace the column with one from a manual shift rig.
