It is currently Sat Nov 21, 2026 4:10 pm
 Post subject: non sycro'd 1st 3speed
PostPosted: Wed Apr 23, 2014 8:57 pm
i understand that the trans in my car isnt going to last long. in an effort to stretch its life a little further is one gear better then another to get on it? like could i romp on it in first and baby 2-3 or vise versa?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Thu Apr 24, 2014 4:02 am
Third gear
 Post subject: x2
PostPosted: Thu Apr 24, 2014 5:57 am
3rd gear in all the 3speeds, and the A-833OD is "locked" meaning the shift collar mates the input and mainshaft together so the unified assembly can take the most abuse...any other gear uses the countershaft gears to change the ratio and added torque tends to cause the shafts to move away from each other and the gears and split input/mainshaft take the abuse while trying to stay aligned.
PostPosted: Thu Apr 24, 2014 1:50 pm
alright. thats kinda what i figured. i guess ill keep my boost low for a while. thanks for the replies guys.
