It is currently Fri Nov 27, 2026 12:05 pm
PostPosted: Tue Apr 22, 2014 1:52 pm
Anyone know the exact length, size, and pitch of this bolt? I needs one for a reassembly. Would prefer not to use a stud.
PostPosted: Wed Apr 23, 2014 9:04 am
Check the posts, one of us has posted it many times before....I just can't remember off hand. I mentioned the size under stainless steel conversions.
PostPosted: Thu Apr 24, 2014 8:49 am
It's been a long time since I have looked at the stock set up. Can you drill clear through and put a nut on the bottom?
Sam
PostPosted: Thu Apr 24, 2014 9:13 am
Sam
Sam,
There is a special boss placed in exhaust manifold area where 123 and 456 converge. It is above and isolated from the exhaust stream. If you were to drill through as you describe the bolt would then breach into the exhaust stream and cause leaking and a fracture point.
If the exhaust manifold is nice and flat and the choke well area is intact and overall in good shape, I think the best plan of strategy is to remove the manifolds and have the remaining broken bolt carefully extracted from the exhaust manifold and a new bolt or stud installed.
PostPosted: Thu Apr 24, 2014 10:45 am
You can view pictures of the bolts by clicking on the red link below my name.
I followed the link and viewed your pics....man, I hope I can get my '73 looking as nice as your '74. Very very nice.
PostPosted: Thu Apr 24, 2014 10:59 am
Also, regarding size/thread, all three bolts are 5/16-18. Great reference courtesy of the fine /6 board members:
http://www.dutra.org/doug/draft-webpage ... -chart.htm
You can find a variety of lengths and strengths here:
http://www.mcmaster.com/#standard-cap-screws/=rofimo
PostPosted: Thu Apr 24, 2014 2:04 pm
my 81 has a 3/8 stud in that location.
81 LeBaron Salon,88 5th ave,79 Aspen SE wagon,79 W150
Don't worry, nothing is going to be alright.
PostPosted: Thu Apr 24, 2014 7:38 pm
Well whudayaknow. I measured the shaft width of both broken fasteners. The bolt from the '73 mani is 5/16. The stud from the '82 mani is indeed 3/8.
PostPosted: Thu Apr 24, 2014 8:51 pm
Metallurgy question: Can you just substitute grade 8 bolts for grade 5 bolts and then tighten them to the same torque? I thought the bolts had to stretch a certain amount before they'll hold long term. I wonder about little things that might not matter in practice, like how does using anti-seize or loctite affect the tightening process?
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Fri Apr 25, 2014 7:52 am
slantfin...
Good question. I'm no expert, but I suspect grade 5 vs 8 vs stainless doesn't much matter on low torque fasteners such as the three that hold the in/ex manis together, as they'll never be torqued so tightly as to approach the deformation ranges of any of these metal types. I've understood that it does matter on high torque bolts (e.g., head bolts), that it is important to use the appropriate type and strength for these. And (at least for steel/cast iron...steel/aluminum could be a different story...i.e., galvanic corrosion risk) to not use any thread lubricant/locker other than a light coat of motor oil, as lubricant will alter final torque values. Not being a guru, for high torque items, I try to learn/follow the manufacturer's assembly recommendations. Figure following the manufacturers' procedures will keep me safe.
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
