It is currently Fri Nov 27, 2026 8:28 pm
PostPosted: Sat Apr 26, 2014 5:30 pm
Just got my old 1980 d100 back on the road. Blew the head gasket running it with a bad clutch. So parts ordered and swapped. had to do some drilling out of exhaust manifold bolts and replaced. I torqued as per Haynes manual and proceeded to drive.
Was ruff running, I new the push rods needed to be changed but was really bad even for that. Allot of backfiring and such. Don't know what possessed me to pull apart the carb but I did and found pieced of carb and brass shavings in the bowl. My old man found out i was looking for a kit around town and ordered me a new carb. I put it on. It was better but would not fully tune. Set the advance and with the old thing chugging a d rocking even at temperature (off and on) i set my advance and it was good. Held 12deg without jumping around. Started to think it was my ability to tun a carb.
Was putting the truck back together because i was moving so the day finally came when i had to drive it 4 hours on what felt like up hill. No guts, had to down shift allot. Had a hard time doing 50 (80kph) and at times would back fire violently. drank gas like crazy. went through over a tank and a half. At one point a few hours in it seemed to get better but still hated hills and start ups.
I just found a few minutes today to look under the hood. was going to do a compression check pulled plug and it was covered in soot. I suspected weak fire but was talking with someone who thought it was fuel delivery. I'm going to check the pump later. I pulled the distributor cap off and my button was not all the there. the part that made contact with the center was broken off. there was metal shavings everywhere. metal on the contact point looked burnt. it was running five minutes before.
Any takers?
PostPosted: Sun Apr 27, 2014 5:33 am
Update.
took the plugs out today. 6,4,2 were covered with soot. 5 & 3 look good but the gap was larger then the rest. 1 was perfect but accidentally broke it :( . I'm running Champion RV17YC's. they have always worked good but have considered a "better" plug. Also pulled out the distributor and used compressed air to blow ou metal shavings and inspected. Could use a new nylon gear and vacuum advance but is "working" and gap was good. I have never touched this until now. I'm going to get some pics. but for now I'm going to get a new cap and button and see.
PostPosted: Sun Apr 27, 2014 9:03 am
Why do you need to change the pushrods? Do you mean adjust the valves? If you pulled the head you should do a thorough valve adjustment. .012 intake and .022 exhaust with the engine hot and idling.
This could be a large part of your problem. Remanufactured carbs are a crap shoot at best. You need to go through the entire carb and make sure it is assembled correctly and that all parts are functioning and set correctly.
Any takers?
The first thing I would do is pull the distributor and completely disassemble and clean it. You need to make sure that the weights and springs below the pickup plate are clean, lubed, and can move freely. You also need to make sure that the pickup plate itself can pivt smoothly. Finally, you need to make sure that the vacuum advance pod still holds a vacuum. Get a new cap and rotor.
The second thing I would do is clean and regap all the plugs.
The third thing I would do is adjust the valve lash.
Then i would go through the carb and check all the settings. Choke. float, idle speed, idle mixture, etc...
PostPosted: Sun Apr 27, 2014 12:07 pm
Sounds like that carb is running rich or you don't have enough spark!
PostPosted: Mon Apr 28, 2014 5:07 pm
Here is a pic of my rotor button I drove 6 hours with.
Tied to start today with a new button so it could be moved around the yard. I think I must have moved the distributor more then I thought. I had one terrible back fire. Like a 12g
PostPosted: Wed Apr 30, 2014 1:50 pm
I figured out what that loud bang was
There is $35 gone. I wonder if the product warranty will cover it?
No this is how i found it under my truck. It might be closed a little from getting it out from under the truck.
PostPosted: Wed Apr 30, 2014 2:07 pm
Replace the distributor rotor with a new one and verify your base timing.
Probably most of your problems are from misfiring due to that broken rotor.
PostPosted: Wed Apr 30, 2014 4:55 pm
In the process. Forgot my timing light at my parents place, it is a 4 hour drive away. Bought a cheap button, just to run it right now and it does sound good. My carb needs to be addressed. Rebuild of the internet. And I have been searching online for headers. Does anyone besides aussie speed make them now?
