It is currently Sat Nov 28, 2026 4:04 am
 Post subject: Clutch fan
PostPosted: Sat May 03, 2014 5:08 am
Is there a way to test/things I should be looking for with my fan. Are new fans still avail and from where?
Id just asoon spend 50 or 75 bucks on a new one and be done with it and not have to worry about it. Engine in truck had alot of miles, gotta be worn Im sure.
My fan is a 5 blade, Im assuming that standard but is there a better fan?
Id like to have too put my front end back together and know that I wont have to fiddle with things again for a long time if possible. Thanks
PostPosted: Sat May 03, 2014 7:24 pm
I believe 7 blade fans came as clutch fans and move more air. I couldn't figure out what's wrong with your fan from you post.
 Post subject: Stock fan
PostPosted: Sat May 03, 2014 8:01 pm
They are 5 or 7 blade depending on the application, if it won't "engage" on a hot engine, you can buy a replacement center at your local auto parts store and bolt your 5 blade fan to the new center section and be done with it.
