It is currently Sat Nov 28, 2026 3:00 am
 Post subject: Heat treated
PostPosted: Sat May 03, 2014 5:25 am
Im prob. going to send a cam to Oregon cams to have a re-grind. I thought though that the original grinds would have been heat treated for hardness, Im assuming Oregon cams cannot do this process so am I looking at a faster wearing cam?
Also I have a cam in my truck now that is new but is possibly a P.O.S made from who knows where, would I be better off sending an original 1980s cam to them to have them re-grind.
I am concerned with metal content, I know that by the 80s metal was already pretty contaminated but its still got to be better than what they are producing today?
Opinions?
PostPosted: Sat May 03, 2014 9:54 am
I believe the term you're looking for is parkerizing.
http://en.m.wikipedia.org/wiki/Parkerizing
I work for a guy who did alot of racing up until 90s and would have cams that were not parkerize wipe out fast.
70 Plymouth Valiant 4dr
PostPosted: Sat May 03, 2014 11:46 am
Ok now t find out what Oregon covers, thanks, I know guys here have had work done thru them so hopefully they will chime in
 Post subject: Yep...
PostPosted: Sat May 03, 2014 12:00 pm
I have had 5 cams ground by them and currently have used 3, no problems on run in and driving/racing. The add a coating to the cam after grinding that looks like parkerizing.
my 2 cents.
PostPosted: Sat May 03, 2014 12:16 pm
A cam from the early 70-'s may be an even better choice. I have seen 3 80's truck cams that have had the oil pump/ cam gear totally wiped out.
If you find a cam that is not worn after 100,000 miles, I would not be afraid to send it for a regrind no matter what year it is. And I would reuse the matching oil pump gear that it ran with.
2 more cents!
 Post subject: Re: Yep...
PostPosted: Sat May 03, 2014 1:37 pm
my 2 cents.
Thanks I will call them and continue asking around/surfing the web and will let you know what I come up with.
PostPosted: Sat May 03, 2014 1:39 pm
2 more cents!
Stupid question maybe but assuming I could find a cam from the 70s would that still be an ok cam to use in a Hyd. engine. It being solid and my own hydraulic?
 Post subject: Yes but..
PostPosted: Sat May 03, 2014 3:55 pm
You will have to pay a little extra to have them groove the rear journal for oil flow like the 1981-1987 cam blanks.
 Post subject: Re: Yes but..
PostPosted: Sat May 03, 2014 5:05 pm
Thats right, thanks for the reminder
