It is currently Sat Nov 28, 2026 2:36 am
 Post subject: Timing cover
PostPosted: Sat May 03, 2014 5:17 am
I saw a post where it was suggested to replace bolts that hold timing cover onto front of engine with studs.
I like the idea, seems like it would make alignment easier.
I bought the J.P Rollermaster multi index ( not that I know a damn thing about multi index :D ) timing chain and with help from here I plan to play with that timing thing so removing timing cover may happen a few times.
Do you guys suggest studs and where might you get them.
I also plan to have some engine items powdercoated including timing cover, do you guys see an issue with this? I know Ill have to put a new seal in but no biggie.
 Post subject: Re: Timing cover
PostPosted: Sat May 03, 2014 9:21 am
Under "High Performance Installation Instructions" on this page check out the
"3 and 9 keyway instruction.pdf" http://www.cloyes.com/Aftermarket/TechH ... fault.aspx
Also anywhere a seal goes, such as timing cover to oil pan and front seal, you don't want powdercoating in there.
Bolt holes if it gets in them you could just drill them out.
I would hope the people doing the coating would know enough to plug the holes, but you never know that's why you need to ask them if they do it.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Sat May 03, 2014 11:44 am
Dave
I may do the coating myself, I have done it with success but it all comes down to how much free time I can devote to it, thanks for the reminder
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
