It is currently Sat Nov 28, 2026 5:42 am
 Post subject: Offset cam bushings
PostPosted: Sun May 04, 2014 4:29 pm
Thanks in advance for any help that comes my way.
Just setting up my cam with a 6 deg offset bushing from Mopar performance. I'm using a roll master gear set. Hole has been drilled and reamed to .405", bushing fits great but does not fill the depth of the hole.
My question is, should I washer up the balance of hole , not worry and bushing wont move way down in there. or get a roll master bushing kit if there is one.
Also any one good at degreeing cams in cars? Having a hard time looking through the licence plate hole. BTW its a 68 dart if that helps.
 Post subject: Goop it...
PostPosted: Sun May 04, 2014 8:31 pm
You can put another bushing there if the cam washer doesn't hold it tight in place. I have loctite or RTV'd the bushing in place. If I knew that was the best spot for the cam and wasn't going to change it again I'd drill the gear attached to the cam in the car as it sits and install a second dowel 180 degrees from your bushing hole.
PostPosted: Mon May 05, 2014 11:39 am
I use / form some lead around the top of the bushing... then cover the area with a larger hardened washer.
