It is currently Sat Nov 21, 2026 5:09 am
PostPosted: Sun May 04, 2014 4:52 pm
hello! I have a Slant Six with 4 speed manual transmission. automatic transmission would be to adapt a 904 slant six, someone has pictures of adaptation to be performed on the crankshaft? thanks
pd: sorry for my english written entirely by google translator :D
225 turbocharger / EFI ARGENTINA
PostPosted: Sun May 04, 2014 8:47 pm
To go from a manual transmission to an automatic you need the following:
Automatic transmission for a slant six
Torque convertor that matches the crank shaft pocket of your engine and the transmission.
a flex plate to bolt to the crank and attach to the torque convertor.
Cooling lines to go from the tranny to the radiator
Radiator equipped with a cooler in the lower section of the tank.
Carburator and kickdown linkage to properly have tranny downshifts.
Steering column or aftermarket shifter to support the automatic and the shift linkage for the selector (if column shift is selected).
Going the other way, is a little more involved.
Hope that helps somewhat.
-D.idiot
PostPosted: Mon May 05, 2014 5:45 am
Maybe you can find someone with an auto slant car that wants tp swap with you so he can have the four speed in his car. Then you both have everything you need.
sam
PostPosted: Tue May 06, 2014 9:31 am
thanks guys! for the answer! , Acquired one transmission CORONADO DODGE 904 Slant Six engine, from the next day to fit my Polara RT!
PostPosted: Tue May 06, 2014 9:46 am
Hi Diego!!! Hola Diego!!!
Yo estoy casi en la misma que vos queriendo armar una 904 para las picadas ... asi que hablemos!!! Abrazo!!!
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Tue May 06, 2014 4:34 pm
hola martin ! charlamos por facebock!
