It is currently Sat Nov 28, 2026 4:42 am
PostPosted: Sun May 04, 2014 5:18 pm
ebay has this listing today:
http://www.ebay.com/itm/Mopar-Chrysler- ... f3&vxp=mtr
FYI,
Brian
PostPosted: Sun May 04, 2014 5:25 pm
I wouldn't call it a good deal.
V8 air cleaner not correct for either the sellers 63 valiant or a true Super Six (it will function fine, but that is an early 70s 318 air cleaner with asticker on it)
318 BBD that needs a rebuild kit. Could be a worn throttle shaft, in which case it needs lots of work to (a) function and (b) function on a slant
No exhaust manifold
No choke thermostat
No kickdown linkage
No throttle return spring bracket
If this is the kind of price one can expect to pay for a factory original Super Six intake, then the time hads come where fabricating your own two barrel intake is cheaper than buying a factory Super Six intake.
PostPosted: Sun May 04, 2014 6:06 pm
Thanks Reed, I obviously don't know enough about this stuff...
PostPosted: Sun May 04, 2014 6:20 pm
I just got an aluminum Mopar Performance intake, BBD and a header and full exhaust system at a swap meet for $300.
No linkage, but it did come with a heat riser block off with a provision for a tube that runs from the header to the intake as a header "heat riser".
It'll never work as good as the stock exhaust manifold, but it's better than nothing at all!
19 Years young with a passion for all things old.
"Four doors for more....screaming passangers..(;"
"There's no replacement for displacement, but my \6 is still cooler than your V8"
PostPosted: Sun May 04, 2014 6:44 pm
No exhaust manifold
No choke thermostat
No kickdown linkage
I agree, not a good deal at all. I have paid quite a bit less for alot more recently.
Reed how can you tell it is the 318 cleaner. I am trying to learn how to tell the differences?
PostPosted: Sun May 04, 2014 9:05 pm
It fits the BBD throat, but has a square end on the snorkel. All passenger car Super Six air cleaners had a round end on the snorkel to attach to tge factory cold air intake system. The square snorkel end also indicates the air cleaner is from a late 60s to early 70s era engine.
I am really nit-picking, but the last time I bought a truly complete Super Six setup I paid $30. Of course, that was about 14 years ago. The set on eBay is a good start, but I would price it around $150, tops.
PostPosted: Mon May 05, 2014 3:09 am
Thanks, easy to identify
PostPosted: Mon May 05, 2014 7:00 am
The super six cars did have a cold air intake tube correct? I don't think I've ever seen one actually on the car everyone seems to just run the air cleaner an nothing else. I feel like getting a slightly colder charge of air with that tube would be worth a couple extra horses as it gets pretty hot right above that engine.
PostPosted: Mon May 05, 2014 8:34 am
Yes. The only factory Super Six equipped vehicles that did not have a factory cold air intake system were the vans. But they are so rare you will likely never see one of those anyway.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot], Google [Bot] and 9 guests
