It is currently Sat Nov 21, 2026 2:19 am
 Post subject: Aaagh!
PostPosted: Tue May 06, 2014 5:01 pm
I tell you, it is getting tiresome to keep buying parts that do not work. I recently purchased a 8.25 rear axle for my car that came out of a 76 Cordoba. Casting number 2852905
I then bought, from a guy on a forum, a sure grip carrier for it with 3.55 gears that came out of A 93 Jeep Cherokee XJ, casting number 18-05-039-905. I was told that as long as the axle has the same splines ( 27) it is a drop in. Went to test fit my gear mesh and discovered that the newer carrier's side bearing races were about 3/16 larger than what came out. I checked the bearing lands and they are also larger on the new carrier. Obviously this won't work.
Apparently you can have 8.25 rear ends and the parts are not as interchangeable as I was led to believe. Either that or this carrier was not a 8.25, even though it is identical to one.
Any ideas?
 Post subject: Snap!!!
PostPosted: Tue May 06, 2014 6:48 pm
The 76 Cordoba is a B-body so measure the rear axle it should fit under a Dodge Charger fine, it may be tight under a Volare/Aspen unless it was a 1979-1980 Cordoba...The swap for the Volare/Aspen is FMJ...so Diplomat, Late Gran Fury's etc...
Jeep Cherokees come two ways with 10 bolt oval covers 8.25" (not so common in early 90's Jeeps, and Dana rear ends...the Dana stuff will not work in the Mopar rear...Getting them from a 90's Dodge Dakota will work though...
:wink:
I serious about junkyard swaps and want a good bedside reader, see if Powell's Books has a copy of Frank Adkins' Chrysler Performance Upgrades... Although you can find everything in it's pages on the web for free, it's sometimes nice to have it all at your fingertips with pictures, especially if you are kind of new to upgrading your car.
PostPosted: Tue May 06, 2014 8:32 pm
The Cordoba is a bolt-in for the Volare. The problem is the axle is from a 1980-83 Cordoba, not a 76. From 80 to 83 there was an option for a smaller bearing race. Now I have to see if the bearing mounting surface is compatible with both sizes, but I doubt it.
