It is currently Sat Nov 28, 2026 1:17 pm
PostPosted: Tue May 06, 2014 5:38 pm
I rebuilt the my Holley 1920 about a month ago as it liked dumping fuel out of the float bowl and would only start by holding the gas to the floor and cranking it over for about 10 seconds. :oops: Yeah, it was really that bad. When I opened it up it was missing the bowl baffle, float spring, and the float was swolen from absorbing fuel.
Did a simple rebuild using a Mike's carb kit, found a new float, bought extra parts carbs for the baffle and springs.
Anyways it ran great after that! Well..better than it did.
Since then I have put on a glasspack muffler to open up the exhsust flow a bit.
A few days ago I realized the car sounded like it was missing, or almost a low backfire sound out of the exhaust while on high idle choke.
It runs smooth at idle, but at mid range rpm it seems like it is missing or backfiring.
Im 100% sure I have no vaccume leaks, I chased a vaccume leak last week, replaced every line with new stuff. Tried adjusting the mixture screw and it seemed to help it a little but it is still doing it at around (I'm guessing 2500 rpm)
At higher rpms though it seems to stop again.
Worked on my cars too much today and my head hurts too much to keep pondering it, going to borrow my fathers timing light, maybe its off..?
19 Years young with a passion for all things old.
"Four doors for more....screaming passangers..(;"
"There's no replacement for displacement, but my \6 is still cooler than your V8"
PostPosted: Tue May 06, 2014 5:56 pm
Also should mention the plugs are brand new, maybe 300 miles on them.
 Post subject: Carb calibration...
PostPosted: Tue May 06, 2014 6:39 pm
the problem with carb tuning is when you change a major aspect of your setup you have to retune everything, changing the exhaust, the timing, etc...puts thing out of the box for a factory carb.
When tuning a carb having a vacuum gauge plugged into a port that always sees vacuum under the throttle blades can do wonders for figuring out what's going on, and a tachometer will help pin it down as well.
At the very least it will show you the relation of the plate openings to how much you have pressed on the Go pedal....but in other aspects you can see if the carb is leaning out at a certain rpm (vacuum drops off), when the power valve opens up (you get lots of power, some black smoke out the tailpipe, and things get better after 6"Hg or so)...
Typically in the mid range you are transitioning from the 'slot' on the side of the plate bore to the main jet and venturi in the main body...if there is a discrepancy between the two you will get a lean out or worse (a miss or if bad..."shooting ducks")....
If it's in the transition slot you may need to richen up the idle mix a little bit to get a little more fuel in there, if the vacc. dips too low the power valve will come to bandaid the situation...if you don't get to an rpm where the mains kick in the PV will stay open and fuel mileage suffers (and cylinder bore wash down can occur if used a lot).... The other item to note is if the gearing of the car is such that you are cruising at 1500 rpm instead of 2000, then you may need to do some research to restrict the high rpm air bleed in the carb so the main jet comes on at a lower rpm....
What jet do you have in there anyway? And what rpm does it start to miss?
PostPosted: Tue May 06, 2014 10:11 pm
Alot of what you've described sounds exactly like what I'm experiencing, on the nose actually!
Amazing that you understood what i was trying to say.
Yes richening up the fuel ratio did help it a bit, but I still have this studder in the acceleration or mid range rpm.
"Shooting ducks" is a good way to put it lol
Never knew just changing a muffler would affect it so much! I must just be too used to fuel injection lol.
I have a #57 jet in there.
I have the bigger float in my carb which calls for the smaller one, but i have the heavier spring, would that be effecting it in anyway? Its all to spec in the carb, all new parts, actually very clean inside there, considering.
PostPosted: Tue May 06, 2014 10:15 pm
Not 100% sure, i have an old sun pro laying around that was my uncles, i may wire that up so i can see what the engine is doing, i hate not having a tach anyways.
My best guess would be 1200-1500? Slightly below cruising speed
PostPosted: Wed May 07, 2014 4:45 pm
1. What type of power valve do you have?
2. A single plunger or a dual plunger two stage...
3. Are the three screws on top of the power valve plunger tight or are they leaking.....creating a lean spot.
PostPosted: Thu May 08, 2014 7:13 am
It is a single plunger.
I did not replace this when I rebuilt the carb as it seemed to be in good working order, good tension, went up and down smoothly, not leaking at the top gasket is sealed very nicely.
I have one that came in the kit, should I just replace it?
