It is currently Fri Feb 21, 2025 10:44 am
PostPosted: Sun May 11, 2014 9:31 am
I just scored the complete kickdown linkage on ebay for $99.49 shipped! (The seller was even kind enough to take pictures of it on the vehicle before being pulled, even the springs and the tiny "c" clip retainers are included!)
:shock:
I know I know, a little pricey, but considering the deal I got on the headers the BBD and the aluminum mopar intake I really think I did pretty well for myself on this one :D
Also should note I am not using a regular air cleaner but making a home brewed "cold air intake" using some 2.5" intercooler silicone elbows, hose clamps and 2.5 inch aluminum intake piping (various bends and lengths ment for hondas)
Now my only thing left to consider is gaskets. Does anyone have any reccomenedations? I know any "oem quality" intake gasket will do, but any special considerations for the thin flanged Hookers?
19 Years young with a passion for all things old.
"Four doors for more....screaming passangers..(;"
"There's no replacement for displacement, but my \6 is still cooler than your V8"
 Post subject: nice
PostPosted: Sun May 11, 2014 9:53 am
try Remflex
PostPosted: Sun May 11, 2014 10:48 am
Will do thank you! I have heard they are less prine to leaks/blowouts
PostPosted: Sun May 11, 2014 3:24 pm
only use the remflex if youre not planning to take off the intake/ exhaust anytime soon. it will split, fall apart, and make a big mess if its taken off. i wouldnt reccomend it for headers.
I am certain there is far too much certainty in the world.
PostPosted: Mon May 12, 2014 9:54 am
Unfortunately I have to disagree with part of this, while yes probably not re-usable if taken apart, I don't feel ANY gasket should be reused. They are however strongly recommended for headers, especially cheap headers with thing flanges that are guaranteed to leak...
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
PostPosted: Mon May 12, 2014 10:29 am
FWIW- I am a total cheapskate and will reuse gaskets if I can. I have sucesfullly reused Felpro intake gaskets and even head gaskets. My one experience with a Remflex intake gasket was that it completely fell apart when the manifolds were pulled off the head. Remflex is great for the exhaust manifold flange to pipe gasket, but I wouldn't use it for the head to anifold union.
PostPosted: Mon May 12, 2014 2:04 pm
I'm not really into re-using gaskets, as long as it seems to hold up well for headers.
PostPosted: Mon May 12, 2014 7:40 pm
Someone please school me on this...where is the super 6 kickdown to be mounted when using headers? I thought it was bolted to exhaust manifold in a coupla places...
PostPosted: Tue May 13, 2014 6:33 am
Lowbrow,
there are two bolts that mount one bracket about an inch below the intake.
I plan on making an extended aluminum or steel bracket to bolt ontop of the EGR block off and bend slightly in and down, drill my two needed holes and bam! Original kickdown with a header.
PostPosted: Wed May 14, 2014 4:30 am
thanks...good to know
PostPosted: Tue May 20, 2014 3:01 pm
I saw someone who had a picture where they were using headers on super six. For the kickdown they just had two spacers going down, used the same 4" bolts and the spacers took the place of the exhaust manifold.
Users browsing this forum: Semrush [Bot] and 65 guests
