It is currently Tue Jun 23, 2026 7:03 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Sat Apr 26, 2014 9:50 am
This is a Great Build! I would really like to see more photos and some details/specs on the build! Thanks for posting! :D
1964 Dart GT
PostPosted: Sat Apr 26, 2014 10:31 am
Thats why I like a color tune. I don't have one to fit a slant though but I have them for other toys. I may look into seeing if they have one to fit the slant.
http://www.international-auto.com/colortune.cfm
PostPosted: Sat Apr 26, 2014 1:28 pm
color tune is OK,and gets you close, but a good wideband is really the best, how are you going to read the color tune while under a load and at hiway speeds?
PostPosted: Tue Apr 29, 2014 9:28 pm
You are absolutely correct, the color tune is an old technology but its cheap and easy for me. I found myself pulling the plugs alot less and only needed minor tuning after using it. But I'm trying to get with the times and get out of the cave. :D
PostPosted: Fri May 09, 2014 6:25 am
Picked up a 4 barrel offenhauser intake and and Holley 4 barrel, going to step it up a little.
PostPosted: Tue May 13, 2014 6:34 am
Made a little video.
http://www.youtube.com/watch?v=oTRl6rCvm5s
PostPosted: Tue May 13, 2014 9:40 am
That is one sweet little Dodge. :D :D :D :D :D :D
 Post subject: d100
PostPosted: Wed May 14, 2014 5:52 am
Matt- your set-up is too cool LOVE the truck 8) 8) Have you put the 4bbl on yet? How about the bypass? I'm getting my grocery list together to replicate your set-up on my 68 Valiant 2dr.
72 Duster blown Slanty (coming soon)
70 Cuda 528 Hemi
PostPosted: Wed May 14, 2014 8:40 pm
I just put the 450 4 barrel on it and it pulls about 700 rpm higher than the 500 two barrel before, this is still running through the one barrel manifold. I am still perfecting the offenhauser intake and hope to test in in a day or so.
PostPosted: Sat May 17, 2014 8:28 am
Started adding the offenhauser intake.
PostPosted: Sat May 17, 2014 10:46 am
Got the intake and supercharger on, also separated the intake from the exhaust and the intake temps are down quite a bit.
Runs a lot better, right up to 4500 rpm, still wants to pull.
PostPosted: Sat May 17, 2014 11:06 am
I would think that if the offenhauser worked better, that the Clifford would be even better yet. Am I wrong in this assumption? I'm not really sure why I think this, it just seems the larger plenum and short fat runners would really shine.
PostPosted: Sat May 17, 2014 11:25 am
Not really sure about the clifford , but over the one barrel intake there is a pretty good difference.
 Post subject: blower
PostPosted: Wed May 21, 2014 6:14 am
Matt- what jetting are you running on that 450 holley?
70 Cuda 528 Hemi
PostPosted: Wed May 21, 2014 1:38 pm
68 mains , 50cc acc pump and 34 nozzel
