It is currently Mon Oct 12, 2026 6:18 am
 Post subject: roller rocker spray bar
PostPosted: Sat Jan 24, 2004 8:32 am
does any one have a step by step instruction for a oil spray bar for roller rockers???
PostPosted: Sat Jan 24, 2004 10:06 am
I just braze a piece of hard line into the cover, then drill the small holes to drop oil on each rocker tip. I put some blobs of grease on each rocker tip, put-on the cover with tube brazed-in, roll the engine around a few times, remove the cover and look for the grease marks on the tube, that is where I drill the .020 holes.
See this photo:
http://www.dutra.org/pictures/engine/pa ... -oiler.jpg
 Post subject: oil source
PostPosted: Sat Jan 24, 2004 1:45 pm
were do you tap the oil from?
PostPosted: Sat Jan 24, 2004 2:18 pm
I drill and tap the boss at the rear of the main oil gallery, then use a short section of hard line to lead-up to the cover. I put a junction (flair fitting) up at the valve cover so I can quickly disconnect the line and remove the cover.
You can use a "T" fitting down at the oil pump sending unit to pick-up oil pressure if you don't have a tapped hole in the oil gallery.
 Post subject: Sending unit
PostPosted: Mon Jan 26, 2004 4:44 am
do you have a pick of the t fitting at the sending unit?
 Post subject: Re: Sending unit
PostPosted: Mon Jan 26, 2004 12:42 pm
Just ask for a 1/8" NPT female run tee. It's brass.
If you want to, you can also buy an inverted flare bushing for the tubeline running up to your valve cover. Then you can just screw the flare nut into that. Any place that has brass fittings and a clerk knowledgeable in his/her terminology will have what you need.
PostPosted: Mon Jan 26, 2004 1:01 pm
Sending unit is only 1/8 ? I know someone who used this method on his /6 and I want to say the size was 3/8" but I can't be positive.
PostPosted: Mon Jan 26, 2004 2:09 pm
The tapped gallery hole is 1/8 NPT and the sender mounting hole on the oil pump is 3/8 NPT
A "T" with a 3/8 NPT male and two 1/8 NPT outlets would be the perfect on to use. (You would need a sending unit with the 1/8 thread, common on the later SL6 and V8s)
PostPosted: Thu Apr 20, 2006 12:27 pm
Doc, I am bringing up an old thread here, But I run my press. gauge off the boss mentioned in this thread; If I Tee it there, and run a Line to the spraybar, and to the gauge, will i still get an accurate reading on the gauge?
Thanks, Greg
PostPosted: Thu Apr 20, 2006 1:55 pm
As long as the holes in the spray bar are small and the flow is not high, then the gauge will read accurately. You should put the gauge sender on a tee right near the block hole.
Actually, it shouldn't matter what the spray bar does, as long as the sender or gauge line is in parallel with the spray bar line (teed) and is near the block. If the flow of the spray bar line is too high, then the whole oil gallery pressure will drop.
PostPosted: Thu Apr 20, 2006 7:21 pm
Thanks Lou, as you might gather, I am working out some kinks with the new parts here.
Thanks, Greg
Users browsing this forum: Amazon [Bot] and 4 guests
