It is currently Sun Nov 29, 2026 11:01 am
 Post subject: Best out of a 7 1/4
PostPosted: Mon Jan 26, 2004 1:56 pm
what is the best gear ratio you can get in a 7 1/4 rear, and where can I find a set?
 Post subject: Re: Best out of a 7 1/4
PostPosted: Mon Jan 26, 2004 2:15 pm
What do you mean by "best"?
Do you want high speed cruise and good MPG or do you want good "off the line" quickness and a low ET on a timeslip?
For a street car which sees a good amount of freeway driving, I use the 2.94 ratio.
PostPosted: Mon Jan 26, 2004 4:10 pm
i wanted a good e.t.....but i don't know what gears will fit the 7.25 rear
PostPosted: Mon Jan 26, 2004 8:51 pm
here ya go baby, don't never say uncle wendell doesn't love you!
<BFG>
http://nationaldrivetrain.com/shopsite_ ... age15.html
Oh yeah, if you're planning blantant abuse it won't last long-- they tend to go **pop**
oof, and don't forget the special tool for "spreading the case"!
-JYH
64 Dart, 69 cuda, and a stack of busted 7.25's
PostPosted: Tue Jan 27, 2004 9:21 am
You don't need the case spreader for the 7 1/4. It has bearing adjusters, with a hex in the center. Remove the axel, and use a bar with a large nut welded to the end. I use an old torsion bar. I am told there are some torsion bars that have a large enough hex, that can be used as is. A 7 1/4 rear with a suregrip, is a lot tougher then people think. I have run the 7 1/4 rear from 1974 till last year. It has many street miles and races behind a legal stock elimintor motor, to turbo and nitrous motors. I have two, one 3.91 ratio, and one 5.13. The car weight has been from 2500-3300 lbs. Have run a best of 13.4 at 97 on nitrous, 13.4 at 104 turbo, in the quarter. 8.16 at 84 in the 1/8 and 1.79 60 foot times. Didn't break it, but felt I was pushing my luck, so did change to 8 3/4.
PostPosted: Tue Jan 27, 2004 1:14 pm
Very true, adding a SG unit certainly toughens up the beast; but finding them 7.25 SG units is one tuff proposition-- they seem about as common as hens teeth!
You know, i only grenaded one while doing a big nasty breakstand burnout. All the rest were while turning, mostly while applying light throttle. On the street no less!
Thanks for the tip on the 7.25, i was totally under the impression that you needed the case spreader thingy to get busy on it, but i haven't serviced one of those in years. I know that the 8.25 is the one that you can adjust with a t-bar. the C-body unit has the right legnth and hex, FWIW.
-JYH
64 Dart, 8.25 SG
69 Cuda, 8.75 SG
SoCal
PostPosted: Tue Jan 27, 2004 2:03 pm
thanx so much for the link, I knew somewher eout there you could get a good gear set for my rear end!
so, lets say I buy one of these things, anybody know a good step by step on installation?
PostPosted: Tue Jan 27, 2004 10:34 pm
Go look around at Randy's website, they have some good tech:
http://www.ring-pinion.com/tech/techind.html
Find a Factory service manual, that has all the step-by step info also.
Users browsing this forum: geotunes and 4 guests
