It is currently Mon Nov 30, 2026 1:40 am
PostPosted: Wed May 21, 2014 10:42 am
How much do I torque the valve cover rubber gasket
PostPosted: Wed May 21, 2014 11:32 am
Snug!
PostPosted: Wed May 21, 2014 1:02 pm
Car Model: Toad Wagon
Snug ..... just. As noted.
On the rubber gaskets, I like to replace the "normal" washers with the triangular intake/exhaust manifolds ones, to spread the load out a bit better. I get less "bowling" at the holes (due to the thicker & softer gasket) that way.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Wed May 21, 2014 1:16 pm
I use a nut driver to tighten the bolts to a firm snug.
