It is currently Fri Nov 20, 2026 3:18 pm
 Post subject: Rear end vent question
PostPosted: Fri May 23, 2014 7:28 am
How's that for a lead in to a joke? I have procured, with the help of one of our forum members, a Ford 8" rear, and will put that in the Dart. There is a vent on top of the axle housing which right now consists of a vacuum line plug with a hole cut into it. I suspect there is something better for this but don't know for sure how the vent is supposed to function. Currently there is a serious oil stain around it suggesting it has been spitting out oil for awhile. The stain, and accumulated grime covers half the pass side of the tube.
Is there a valve of some kind I can buy the vent this in the proper way? What does the vent do?
Thanks for any insights into this.
For what it is worth, Lou Madsen drove my Dart last week end, and said the amount of noise in the current 8.25 Mopar rear is pretty minor. He has put 100,000 plus miles on one that sings an aria compared to mine, and states he is not worried about it. Thanks on all counts Lou.
Sam
PostPosted: Fri May 23, 2014 2:31 pm
don't over think this one Sam.. the vent just vents..
as the oily air vents out and settles on the housing dust and grime will collect around it. the vent that's in there is most likely fine.. just clean it and go.
the vent allows for the expansion of the air and fluids during tempature and is not a critical component like say having the correct pinion depth or back lash on yor gears.. even a crude drilled hole on top would do.. it just would let all sorts of scum back into the gear oil.
PostPosted: Fri May 23, 2014 2:39 pm
Car Model: '23 T-bucket
One thing you could do is run a 1/4" hose off the vent fitting on the axle tube, up to a fuel filter attached to your frame rail. This will let the rear breath as it should, and keep out dust/dirt, while keeping oily vapor inside the axle where it belongs.
It's a trick that the 4X4 guys use, but they do a lot more off-roading than you'll probably do.
Roger
PostPosted: Fri May 23, 2014 4:35 pm
There is oil around the vent because I dragged it back to my house from TN upside down. I think it was dry when I got it.
Regarding your other post: No drain plug. Could use a suction gun or I would just pull one axle and tip it up with the housing end in a drain pan and let it drain. I might also just pull the pumpkin and look everything over inside, clean up the housing innards a bit, and put it back together.
PostPosted: Fri May 23, 2014 6:08 pm
Thanks guys. I have tipped the axle up and drained it. I then put some fresh oil in and will let that sit and drain it again. I asked a Mustang guy this evening if they ever put drain plugs in them, and he thought no. Boy was that gunk awful looking.
Probably good advice about pulling the pumpkin. This project is expanding. The lug studs tsm sent me have a 5/8" base, and require drilling the axle stud holes out. It seems like over kill to me, but if they think it is a good idea, I guess I will do it.
I like the idea of a tube vent. Maybe nothing more than a "u" shape that points up and then bends back down. Seems to me the Mopar axle has something similar.
Thanks all for advice.
Sam
PostPosted: Sun May 25, 2014 7:55 am
Those must be special studs. I bought some Milodon long studs from Summit and they were press in and required no drilling. I installed them then cut to length with a grinder.
PostPosted: Sun May 25, 2014 10:08 am
Moroso and ARP also sell press-in studs. Trust me, you do NOT want to try and drill those out. It is not fun. :shock:
 Post subject: vent
PostPosted: Sun May 25, 2014 7:05 pm
I think the vent should stay relatively clean as there isn't a ton of vapor coming out of it. Rear end lube is pretty high viscosity and the rear doesn't heat up like the engine or anything.
My 7.25 just kicked the bucket and I installed a freshly rebuilt 8.75 unit and it is as quiet as a church mouse! I love it.
Also, my new unit as 3.55 gears and those seem to work well with the slant. Noticeable improvement in low end acceleration (from the 3.23 ratio).
Brian
 Post subject: pic of my vent
PostPosted: Sun May 25, 2014 7:27 pm
Here is a pic of the vent on my rear end. I didn't rebuild the unit, so I don't know where it came from. It is brass and has a little black vent cap at the top.
http://s785.photobucket.com/user/67dart ... f.jpg.html
brian
 Post subject: vent
PostPosted: Sun May 25, 2014 10:26 pm
Obviously it's both a T for the brake lines and a vent...
PostPosted: Mon May 26, 2014 4:00 am
Brian, Thanks for the photo. Do you know what kind of valve that is? I think the reason this one leaked so badly is the seal was bad between the brake "T" and the axle housing. The PO had fabbed a bracket to hold a standard "T" fitting, and there was no O ring or gasket there under the bracket. It is all a little loose and wobbly.
Dennis and Lou, Yes these are special studs. They are not that much longer than normal. They are nothing like the extended studs you see on race cars. They are longer by about 1/8" and the extra length is all in the wider shouldered base of the stud. I have mixed feelings about this part of TSMMFG's design here. Since the hub center on the Ford rear is smaller than the Mopar, they center the rotor by making the shoulder of the stud longer and extending it through the axle flange. Then you drill the rotor stud holes out to 5/8" and they fit around the extension of the stud to index them. This part of the extension is knurled like the rest of the stud base.
One thing that concerns me a bit is that the knurled part looks like it may extend too far and interfere with the wheel. However, the tech guy at TSMMFG assures me this will work. He also thought no drilling would be required. But when the machinist looked at the axles and suds on Friday, he said he thought the base of the new stud was bigger diameter than the hole in the axle and would require drilling.But the old studs were still in place. I am not sure you could tell without removing the studs, as there was a fair amount of road crud in there. I am sure he will not drill if it is not needed.
To further add to the confusion here, Lou, the studs you gave me for my Mopar axle were too narrow at the base. Once I had banged out the old studs, those new ones just dropped in. I ended up putting the old ones back. So apparently not all 1/2" studs have the same base diameter. I will return these at some point. Thanks for for the thought though. I did appreciate the gesture even though it did not work out.
For what is is worth, TSMMFG is the web address of The Street Rod manufacturing company. They make rear disk brake set ups for a variety of old RWD drum brake axles. I have been very happy with the kit I put on my Mopar rear, which did not require any special studs or indexing. I just put the new rotors right over the axle hub and settled in onto the stock studs. Because the old set up works so well, I have placed a fair amount of trust in their design ideas. I spoke to the tech guy personally, whose name I think is Cliff. He seemed very nice, very helpful, and trustworthy. We will see. To be fair, my set up is ten years old now. They may have changed their approach on all the rears. The brackets now come powder coated an impressive bright red.
Sam
