It is currently Wed Sep 30, 2026 2:07 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sun Apr 27, 2014 9:46 am
This is his car!
PostPosted: Sun Apr 27, 2014 9:50 am
So with that said..i WILL go ko3 into to4b..here we go...!!! I may upgrade to a ko4 compressor side down the road depending on IAT..which is useually better in compounds at anygiven load or boost.
PostPosted: Sun Apr 27, 2014 11:35 am
Some mockup/test fitting...will be gusseted and turbos "hung" by hiemed braces...
PostPosted: Sun Apr 27, 2014 11:36 am
Ran out of argon...small town problems..should have this potion welded and wategate vband on by mid week
PostPosted: Wed Apr 30, 2014 10:24 am
Some 2d cad rendering im workin on for some cnc'd plasma cut sheet steel exhaust/turbo manifold components..i didnt like the packaging of my tube headers and want to do a turbo manifold similar to the sheet aluminum intake i made..Image
PostPosted: Wed Apr 30, 2014 12:53 pm
Im refamiliarizing myself with solidworks and am using draftsight for my 2d plasmacam stuff...going to try to aquire a SLA-3d printer in the next year..i hope to unviel some amazing slant six prototypes soon after...ive got vision for days and days.
PostPosted: Thu May 01, 2014 9:01 am
Off to cnc plasma guy...
PostPosted: Mon May 12, 2014 6:15 pm
Been busy..hence quiet..been knockin out some chassis work..
Im still a believer in compounds..but ive decided on my previous m90 plans..i just didnt want to deal with potential exhaust/turbo interface problems in the remote desert in which i roam..maybe ill pull it off on a streetcar in the future..but do stay tuned....ive got a really trick blower
Setup well under way..ill post pics on completion..heres my rear end for you all to look at for now..Image
PostPosted: Mon May 12, 2014 9:49 pm
Car Model: 1964 Dart GT
A few years back, Hotrod mag did a spot on a 6 turbo in series. Something like 1700 hp out of a 2 litre VW if memory serves.
Your project sounds like a fun one. Do you have a motor yet? What do you have or are planning on building to take this power?
Be sure to post pics when this does start up.
PostPosted: Tue May 13, 2014 10:48 am
Thanks..it should be fun..yeah ive got a pair of 225s..one cast/one forged..this one will be a cammed stock.cast crank shortblock..head studs, oringed, ported by I with stock valves....remote mounted m90, blow thru cv's on my own sheetmetal intake..
PostPosted: Mon May 26, 2014 11:36 am
Edit
PostPosted: Mon May 26, 2014 11:39 am
Edit
PostPosted: Mon May 26, 2014 11:40 am
Edit
PostPosted: Mon May 26, 2014 11:45 am
PostPosted: Mon May 26, 2014 11:48 am
