It is currently Mon Jun 22, 2026 7:50 pm
PostPosted: Tue May 27, 2014 8:43 pm
Has anyone here used Hooker Super Comp headers? I notice the mounting flange on the headers is 3/8" and the mounting flange on the Cliffy ( and the stock intake) is 1/2". Should I grind the intake down or find some way to space the headers up? What did you do?
PostPosted: Tue May 27, 2014 9:16 pm
Car Model: 64 Valiant
Some people tack weld a spacer to the header flange to make it even with the intake flange.
PostPosted: Wed May 28, 2014 3:34 am
Weld a 1/4" nut in each place the washers seat.
 Post subject: Hooker Header flange
PostPosted: Wed May 28, 2014 1:38 pm
Car Model: 1967 Barracuda Notchback
My original headers (1972) came with a set of 1/4" thick washers ground off to make them "C" shaped. These were installed on the mounting studs, on the exhaust flange side, making intake and exhaust flange heights equal. OEM triangle washers were installed over these.
Ken
