It is currently Sat Sep 19, 2026 4:55 am
PostPosted: Wed Jun 04, 2014 7:39 am
I'm nearing wit's end with my 1980 truck. Missing/stumbling at idle bad. I've tried multiple carbs and everything I know. I'm thinking the intake manifold has a vacuum leak or maybe timing chain has jump a tooth.
Recently I bought a NOS Holley reman, which is definitely the right 1945 for my truck. When I adjust the curb idle speed on the carb, there is a spot where the motor starts running way worse. The adjustment is not smooth.
Is there anyone on this forum that builds /6s? I am at a point where I am likely going to find a local shop to build a complete motor for me. Basically I have given up and the /6 appeal is waning. After work, I'm spending each evening in the garage getting nowhere.
PostPosted: Wed Jun 04, 2014 8:47 am
Do you have a vacuum gauge and timing light?
this article is a simple and helpful start.
http://classicinlines.com/vacuum.asp
1964 Dart GT
PostPosted: Wed Jun 04, 2014 8:57 am
I'm a little hesitant to post this, but: Have a fire bottle handy, put a small amount of fuel in a spray bottle. Idle the engine and spray a bit of fuel on the gasket area. You will hear a change in the idle if you hit a leak.
This is an old school test, and does have it's hazards. I fact I would be extra careful on a slant six, as you will be spraying fuel onto the exhaust manifold as well.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Wed Jun 04, 2014 9:23 am
Yiakes! More like old phool... LOL
Just spray carburetor cleaner around gaskets of intake system. No back flash if it catches a flame, and tis stream is easily controlled and directed.
A warped carburetor base may be hard to find by spray alone as it is too large a leak; remove carb, and put a straight edge on its base in several directions looking for gaps. If power brake equipped check booster for vacuum leak.
PostPosted: Wed Jun 04, 2014 9:31 am
hey thanks for the replies gents
I got a reman brake booster on order.
Yes I have vacuum gauge, timing light, even an old Sears engine analyzer. I've spent many hours playing with the idle and mixture screws and the timing. I called a highly reputable shop today and I am going to drop her off next week and let those guys keep her as long as they need.
I might try the spray bottle check. I hold myself responsible for any advice I may heed.
Edit
I have some carb cleaner on the shelf.
PostPosted: Wed Jun 04, 2014 12:29 pm
what do you mean by
NOS Holley reman
is it NOS?
or remanufactured?
carbs rebuilt by the mass-remanufacturers can be troublesome
and have you set the idle air fuel mix,
adjust for max manifold vacuum,, but remember to bring down the idle speed between changes.
http://forums.holley.com/entry.php?429- ... lley-Carbs
PostPosted: Wed Jun 04, 2014 12:44 pm
:? Your vacuum gauge should answer this shouldn't it?
1964 Dart GT
PostPosted: Wed Jun 04, 2014 12:56 pm
Reman by Holley
I said NOS because the PN is discontinued
I am getting 17 on the vacuum gauge but it jumps all around because of the missing. Basically this problem is out of my league methinks.
PostPosted: Thu Jun 05, 2014 5:28 am
May be missing because of stuck valve, or incorrect valve lash adjustment.
PostPosted: Thu Jun 05, 2014 6:59 am
I adjusted the valves live. Took two days to do it. But I have never done that before. Every vehicle of mine before this was done statically. Maybe I screwed them up. Anyway, I'll report back in awhile when I get her from the shop.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
