It is currently Wed Jun 17, 2026 3:01 am
PostPosted: Fri Jun 06, 2014 5:21 am
Hello Transmission Sages
I would Like to know a part # for the Throttle Lever Shaft Seal.. This seal is under the kickdown lever in the Valvebody...
I know these come with rebuild / reseal kits, but I want to buy them ala carte.
Please Do not give me an ATP part #.. I Bought 10 of them from rock auto and they are boxed wrong.
This is the Seal I am Looking for:
This Is what currently comes in ATP Part # TO-29 (they List this as The Seal pictured above.. but its not :-()
Any Alternative/ Equivalent part#'s in Timken, SKf, national Etc
Would be appreciated.
PostPosted: Fri Jun 06, 2014 6:45 am
Greg, you probably could get one from a parts store, or better yet a local transmission shop for a few bucks.
PostPosted: Fri Jun 06, 2014 7:20 am
Thank you WJAJR, But I am looking for a part# on these.
PostPosted: Fri Jun 06, 2014 8:33 am
The seal you received looks like it might be a front pump seal? If so, they look very nice. Also if so, I would happily buy some of yours, or order some from Rockauto.
PostPosted: Fri Jun 06, 2014 9:29 am
Oh DARN! I changed that seal in 2009, but could not find the part number in all my records on that car. I realize now that I will need that p/n for another 904 soon. I did see that I changed the seal when I had the oil pan off, and I cut a 2.5" hole in the floor above the lever for access. (Not a pristine car.) P.
PostPosted: Fri Jun 06, 2014 9:40 am
Per the 70-71 parts manual, chrysler # 2466548 crosses to ATP 13308 per napa's site. The napa site picture seems similar to what you showed, $1.17. Some are listed on ebay as well.
Edit: I know you didn't want an ATP# but judging by the box you have ATP TO-29, not 13308. This sounds like a catalog issue not a misboxed issue.
PostPosted: Fri Jun 06, 2014 9:54 am
Poser
I will be dropping by A&A next Wed. evening. I can pick Rick's brain -prolly has it in stock.
PostPosted: Fri Jun 06, 2014 10:52 am
I have 10 of them that I dont Need..
They look like wat you want But I think the diemensions are incorrect.
Check on the front Pump seal and then compare it to the measurements in my pics... If you can use them Then you can have a few.
PostPosted: Fri Jun 06, 2014 10:58 am
Problem is 13308 Does not exist on atp's Catalog / Inventory and When I bought many of these last Time I got atp to-29 and they were correct.
Atp's site even lists the Dimensions of to-29 as similar to what I have in the above pictures of the small seal.. Somebody goofed..
PostPosted: Fri Jun 06, 2014 11:07 am
My local napa shows them in stock per the site. Assuming you don't have a napa near you - if they are the right ones, want me to buy you several and mail?
PostPosted: Fri Jun 06, 2014 11:42 am
I would buy 2 if they are front pump seals also.
Rick
PostPosted: Fri Jun 06, 2014 1:38 pm
thanks for the offer, but there are napas here too.. so I can get them from them.
PostPosted: Fri Jun 06, 2014 1:41 pm
Rick is da man!
while you are there,
maybe see if you can get me all aluminum drums and rollerizied everything for the 904 for under $1000
:lol:
PostPosted: Fri Jun 06, 2014 1:46 pm
I wonder if that is correct... the picture looks a lot more like the shift lever seal rather than the throttle lever.. I will have to order a few in and see.
PostPosted: Fri Jun 06, 2014 1:54 pm
Poser
Rick is da man!
:lol:
Yep, it is very depressing looking at all the stacks of goodies knowing that I can't afford most of it. You should see a stack of big block cross ram intakes when he gets a shipment from the foundry. First I want to cry -then I want walk out with one and see if he notices!
