It is currently Thu Jun 11, 2026 6:21 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sun Jun 08, 2014 2:22 am
An Accusump is pretty simple, and if you're going to run one of them out of oil, a pan that will live on a street car isn't going to do the job either.
Slow down around corners. Problem solved. :lol: :lol: :lol: :lol:
Just asking, but have you had any bearing problems or does the momentary pressure loss just spook you?
PostPosted: Sun Jun 08, 2014 6:00 am
"Slow down around corners..."
Yeah, right. He's probably also looking for drop spindles and a fiberglass roof for an 89 B200! :D
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Jun 09, 2014 3:07 pm
Thanks again for the input everyone.
Greg: I am not so worried about things falling/sucking up, but more about trapdoors sticking shut eventually. Maybe not a big deal, but I am a fan of simplicity when at all possible.
Dennis: No bearing problems yet, just trying to plan ahead for stickier tires and/or tricky corner combos in autoX or road courses (higher/longer g's). Believe me, I am not one to be spooked easily...
The pans I have on my 64 Dart and 66 Valiant seem to be doing the job with only 3/4" of additional depth, kickouts (8 qts), and static baffles, AND in cars with streetable tires. With slicks, maybe not... I doubt this new 64 Valiant engine/pan project will see g's you can get with slicks as it is even more of a street car.
Joe: I would LOVE to lower my 89 B350, but that's pretty far down the list. Replacing the 360 with a turbo 225 might be higher up on the list... :shock: :twisted: I can tell you that my 68 Dart motor on 6 psi puts out more power and torque than that 360.
Cheers,
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
