It is currently Thu Nov 19, 2026 10:40 pm
PostPosted: Mon Jun 16, 2014 3:32 am
Car Model: '23 T-bucket
About at the point on the T-bucket to order gauges. Want to go with an electronic speedo and pulse generator at the trans.
Speedway offers generators for Ford and GM trans. As I recall, the 904 uses the same thread size and pitch as GM, but my memory has failed me before.
Can anyone confirm this for me?
Thanks.....Roger
 Post subject: Gm...
PostPosted: Mon Jun 16, 2014 6:50 am
I used an Autometer 5291 on my car and it was mopar/GM, fit perfectly...if going junkyard I think the mid-90's dakotas had a pulse generator like this as well for their speedos.
PostPosted: Mon Jun 16, 2014 8:46 am
Great info - thanks!
PostPosted: Mon Jun 16, 2014 3:06 pm
What year is the 904?
Early units (cable type) have a small speedo gear opening.
PostPosted: Mon Jun 16, 2014 3:47 pm
Thanks, but all I have are linkage trannys. Still good info for those with earlier cars, though.
Roger
 Post subject: Re: Gm...
PostPosted: Mon Jun 16, 2014 3:50 pm
HMMMMM! I still have a dead '95 Dak out in the driveway I haven't towed away, yet. I just might have to check that out.
Anybody know if the generator signals the speedo, or the ECU, which then drives the speedo? Wait!...I have a Haynes manual out in the garage....I'll check it out myself.
Thanks much for the guidance, DI.
Roger
 Post subject: Actually...
PostPosted: Mon Jun 16, 2014 5:46 pm
Kudos for the Dakota lead actually go to Joshua Skinner!
:wink:
 Post subject: Re: Actually...
PostPosted: Mon Jun 16, 2014 6:50 pm
:wink:
Fair enough.....Thanks to him, too.
Roger
PostPosted: Mon Jun 16, 2014 10:24 pm
Keep present speedo pinion and adaptor unchanged. Buy GM p/n 25526374 for about $25 from gmpartsgiant.com; installs in line with speedo cable.
