It is currently Wed Oct 14, 2026 7:11 am
PostPosted: Mon Jun 16, 2014 10:52 am
I am sure this has been covered but i cant find anything on a donor car list
I recall a friend saying any late A body car but what cars would be on the list? Which is the best year to look for.
I am wanting to replace the front to disk..rear brakes/rear end
brake master and if it will work the carb linkage and kickdown as I want to switch to a weber
any help would be great... also if you think I am missing something let me know. I want to use as much from the donor car as I can. :shock: [/b]
66 Dart Wagon SL6
93 Dodge Truck S6
PostPosted: Mon Jun 16, 2014 11:25 am
A 1973 or newer A body with disc brakes and an 8.25" rear axle would be my donor of choice and hopefully a manual transmission car to get a more performance oriented axle ratio. The cable throttle pedal will be okay regardless, but the transmission throttle pressure linkage obviously has to come from an automatic trans car.
 Post subject: Yep...
PostPosted: Mon Jun 16, 2014 6:13 pm
Sadly, the Pick-A-Part out by Junction had a 1975 Valiant that had Discs and rear axle for you...the owner sold the right side Spindle to someone in Louisiana, sadly... You might cruise through there and see what else is available...most of the 1973-1980 Plymouth and Dodges are picked clean though.
