It is currently Sat May 02, 2026 2:32 am
Post new topic  Reply to topic  [ 397 posts ]  Go to page Previous 112 13 14 15 1627 Next
PostPosted: Sun Jun 22, 2014 5:17 am
That will tend to raise your crankcase pressure...
Now the big questions: why, and how to prevent it next time.
PostPosted: Sun Jun 22, 2014 2:58 pm
Now that is kind of impressive. In it own bad way.
I think that should be added to the busted slant Trophy.
PostPosted: Sun Jun 22, 2014 6:26 pm
Going to check for a broken wire or bad connection to the plug.
Easy stuff first
Will
PostPosted: Mon Jun 23, 2014 8:17 am
I agree might be a one cylinder misfire of some kind.
PostPosted: Mon Jun 23, 2014 8:33 am
What's the data from your Racepak say?
:D
PostPosted: Mon Jun 23, 2014 1:21 pm
Racepak in the future. The only info I can datalog now is map, fuel and spark. But as usual it was not switched on. Injectors were flowed 3 days befor the race, will check them again soon.
PostPosted: Fri Jul 04, 2014 6:34 am
All injectors check out good. Need to look elsewhere.
Will
PostPosted: Mon Jul 07, 2014 1:12 pm
Site Admin
Have you checked the rod journals to verify they are indexed correctly? The grinders tend to follow the crank throws, and few have the equipment to correctly index the timing of the throws. if that throw is early or late, it could play havoc with the tune on that hole.
Also, I've had cranks that have come out with errors in stroke. Engines that one throw with more stroke than another.
CJ
PostPosted: Wed Jul 09, 2014 6:36 pm
I take my cranks to a shop that specializes in crankshafts. He has been able to fix some that have been messed up by slandered machine shops. If iI don't find any thing else I will check it.
Will
PostPosted: Wed Jul 09, 2014 6:39 pm
Shop tours given daily. Bring beer.
PostPosted: Wed Jul 09, 2014 7:16 pm
:D
PostPosted: Thu Jul 10, 2014 6:23 am
Need to make a pilgrimage one of these days... Will definitely bring beer.
PostPosted: Thu Jul 10, 2014 6:45 am
Now see if you were coming to Carlisle you could make an easy side trip to wills on the trip up or back.
PostPosted: Thu Jul 10, 2014 4:40 pm
Shotgun!
PostPosted: Sun Jul 20, 2014 6:37 pm
I've got an extra week of vacation this year. Bike trip east sounds like fun. :D
