It is currently Wed May 20, 2026 10:45 am
 Post subject: Parts id needed please
PostPosted: Sat Jul 05, 2014 6:46 am
Heres what i have. A 51 Plymouth Cambridge with a built up slant 6 4 bbl headers cam etc' 1 wire gm alternator. I want to buy an extra icm and ballast to have on hand and dont know whats in the car. Note the black goop comming from ICM
ICM by ML Spooky, on Flickr
Ballast
Ballast by ML Spooky, on Flickr[/img]
PostPosted: Sat Jul 05, 2014 6:56 am
icm number111850 0420
ballast 5206436 23979
as far as i can read
Pics of the car https://www.flickr.com/photos/mikesbig4 ... 780442960/
PostPosted: Sat Jul 05, 2014 9:02 am
Nice car....my current project is a 51 DeSoto Sportsman.
PostPosted: Sat Jul 05, 2014 9:29 am
Thanks Sandy! I bought this car last week. runs and drives great. Everything rebuilt or replaced. The only problem is the builder is 77 years old and built so many cars he cant remember parts etc.
51 Plymouth Cambridge with / 6
 Post subject: Components
PostPosted: Sat Jul 05, 2014 11:21 am
Both items are typical mopar EI...
Standard Motor Brand used to be the best, but not everything is still tip top quality. For Replacements just ask for a Ballast Resistor for a 1972 Duster with the 225 , and the EI module just ask for a 1976 Duster.
Mopar Orange Box and knock offs are chinese junk now, if you aren't a purist, you can remove both and rewire the system to use a GM HEI module and they are more common over the counter no matter where you drive to...
PostPosted: Sun Jul 06, 2014 6:13 am
Thanks I was sort of right on module. Might look in to hei at a later date. Too late to be a purist. The whole engine / car was modified.
PostPosted: Mon Jul 07, 2014 3:56 pm
Hum all ballasts i look up for a 72 duster with slant 6 show 4 connectors in stead of 2 like mine. Or is there an optional 2 post one?
PostPosted: Wed Jul 09, 2014 2:38 pm
auto zone duralast ballast cr107 module cr109 just in case someone is searching
PostPosted: Sun Jul 20, 2014 4:24 pm
I think you got your answer, but in case someone's still searching, try looking at stuff a year or two older. The 2-post version was used in cars without Electronic Ignition. 1972 was the transition year-- some cars with Electronic Ignition, some without.
- Erik
