It is currently Tue May 19, 2026 4:37 pm
 Post subject: Headlight switch ground
PostPosted: Wed Jul 09, 2014 8:51 pm
I am installing a new headlight switch on my 63 Valiant, and I am wondering:
Why is there a ground tab riveted to the rear end of the metal frame?
I am tempted to add a ground wire here, because you can't have too many redundant ground wires, but what is it for?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Thu Jul 10, 2014 10:23 am
Generally it is for the dome light. You know, when you rotate the switch all the way in one direction the dome light comes on? Domes usually (in the older stuff) run to ground. With a clean metal dash there is no need for an extra ground.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
