It is currently Tue May 19, 2026 5:02 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sat Jul 19, 2014 2:55 pm
Happy to help. For what it is worth, the slant six in my brother's 1983 van is running a stock 1983 hydraulic cam that it 8 degrees advanced and the motor runs great and has 21 inches of vacuum at idle.
From the 1983 Factory Service Manual for a Dodge van, the hydraulic cam events are as follows:
Intake valve opens 6 degrees BTDC
Intake valve closes 42 degrees ATDC
Exhaust valve opens 36 degrees BTDC
Exhaust valve closes 12 degree ATDC
Valve overlap = 18 degrees
Intake duration = 228 degrees
Exhaust duration = 228 degrees
Looking at that, I say your non-rebuilt slants look fine and the rebuilt slant lookes like it has been set up for a little more low-rpm power. Leave them all alone and you will be good.
EDIT- looks like you already knew all this. I still say those cams are installed fine. I surmise that the factory used the .006 lifter movement as the measuring point for cam timing events. I read somewhere that .006 is the ASE standard measuring reference.
.006 is fine and dandy for both intake and exhaust valve opening points, unfortunately the .006 rule does not apply for the closing points, @.006 intake closing the degree wheel is reading 52 ABDC. It should be reading 42 ABDC if the @.006 rule works here.
The dial indicator reads 12/13 ( before valve closes ) thou when the 42 ABDC degree reading is showing.
This reading is approx 6.5 thou away from where it should be?
I check the exhaust and it is the same scenario.
@.006 just as the exhaust valve is opening the degree wheel reads 36 Degrees BBDC just as it should ( using the .006 rule )
Problem is 12 degrees on the degree wheel ( thats when the valve is supposed to be closed according to the FSM ) the dial indicator is still reading 12 thou instead of the expected 6.
A difference again of .006 thou
Both on the closing sides.
Ive searched high and low for an explanation to this and have got a lot of good feedback but no definitive resolution on why I am seeing what I am seeing :(
PostPosted: Sat Jul 19, 2014 3:04 pm
I know this should be good news but I was hoping to find something way off explaining the poor vacuum issue I was having I.E 13 at idle off the manifold.
(1) vacuum leak
(2) timing way off
(3) some other vacuum related issue
Have you verified that the timing mark on the vibration damper you are using is accurate? It doesn't matter if it is new. I have purchased brand new dampers only to measure them and find that the timing mark was 4 degrees off.
Have you verified that all vacuum hoses are routed correctly? PCV valve in good shape? Choke pulloff vacuum diaphragm still holding a vacuum? All ports on the carb that should be capped ARE capped?
Does the truck have power brakes? Have you done a vacuum reading with the brake booster disconnected and the line to the booster plugged? Boosters can fail in ternally and booster check valves can also fail.
Just a quick check- you are setting yout timing in degrees BTDC, not ATDC, right? That is the kind of mistake I would make (and have made), which is why I ask.
I did check all of these things and then some at the time.
Head is off at this point, all disassembled. I am in the middle of doing some head work I.E oversized valves and mild porting/cleaning up/ new hardened exhaust seat ect.
It will go back together sometime soon hopefully but with the super six set-up, better ignition and a different more appropriate cam (for what I want it to do ) that will have a cam card.
It may be one of those mysteries that just will never be solved.
The only thing at this point I am questioning is the condition of the "new " camshaft.
Looking down at it thru the lifter bores it looks brown, really brown on the outer edges. I would expect a cam with only 18 miles on it too be shiny and pretty.
I need to pull it out to have a better look.
Quote: Just a quick check- you are setting yout timing in degrees BTDC, not ATDC, right? That is the kind of mistake I would make (and have made), which is why I ask.......
Maybe clarify on this one just so I am sure we are on the same page.
PostPosted: Sat Jul 19, 2014 3:26 pm
I think you should try installing one of the old stock cams from one of the two unrebuilt motors you have and see how it works for you. Who knows what the engine builder put in there, or what the cam company provided the builder for a "stock" cam.
When I say set the timing in degree BTDC and not aTDC, I simply mean make sure the timing scale you are using to set your timing has the numbers on the passenger side of the block with the numbers counting down as they get closer clockwise to the 0 or TDC mark. Some timing tabs have up to 10 degrees marked on the ATDC side of the TDC mark and I just wanted to verify that you weren't possibly using the numbers on the ATDC side of th enotor to set your timing.
PostPosted: Sat Jul 19, 2014 3:31 pm
Did you ever use these measurements to degree the cam in your brothers van?
I am under the impression that without a standard of measurement there is no way of telling when the timing events shown in the FSM are supposed to occur on the degree wheel.
My search for this standard of measurement is covered briefly in the prior post AKA .006
PostPosted: Sat Jul 19, 2014 3:33 pm
Actually, you can figure out the cam events on the cam yourself. You already ahave the degree wheel installed, so just note at what degree the intake reaches .006 lift and then at what point it returns to .006 lift. That will give you the intake duration. While the cam is unde the dial gauge, note how high the dial gauge indicates. That gives you the lift.
Now do the same for the exhaust lobe. Then you will have the intake and exhaust durations, lifts, opening and closing points, and from there you can work out the overlap.
Yes this is how my timing scale is set-up and so yes I have been reading it correctly.
PostPosted: Sat Jul 19, 2014 3:35 pm
When I timed the cam in my brother's engine I used .050 as the point of measurement for valve events. I was using a custom ground cam at that time.
I have since pulled the custom cam (after the cam locator dowel broke off) and installed a stock 1983 hydraulic cam. I didn't degree the 1983 stock cam. I just slid it in, put on the lifters, turned the key, and let it go.
PostPosted: Sat Jul 19, 2014 3:42 pm
Actually, you can figure out the cam events on the cam yourself. You already have the degree wheel installed, so just note at what degree the intake reaches .006 lift and then at what point it returns to .006 lift. That will give you the intake duration. While the cam is unde the dial gauge, note how high the dial gauge indicates. That gives you the lift.
Yes in a couple of posts back I showed a map of where I had taken quite a few measurements, unfortunately I am still at a loss for how these coincide with the FSM specs.
FSM Intake opening 6 degrees BTDC.........OK at 6 Degrees BTDC I am on the .006 mark of lift
FSM Intake closing 42 degrees ABDC......Ok at 42 degrees ABDC dial indicator reads .013 of lift still before valve closes.
FSM Exhaust opening 36 degrees BBDC.........Ok at 36 degrees BBDC I am again at the .006 reading on the dial.
FSM Exhaust closes 12 ATDC......At this point when I am at 12 on the degree wheel I am also at .012 on the dial.
I am confused on how do I know that these events are in correct time.
Again that is why I am comparing cams at this point. Dont know what else to do!
I can map them out but proving that events are happening at the correct time is where I am stuck!!
I hope you understand with my ramblings where I am at. Maybe even have a solution?
PostPosted: Sat Jul 19, 2014 4:07 pm
I am confused though on how do I know that these events are in correct time.
OK- when you map valve events on a cam, you have to pick a consistent level of valve movement to measure for both the opening and closing events. For example, you are measuring the valve opening events at .006 inches of lift. This is fine. I used .050 inches just so I had some fidge room to account for tool deflection, wobbly bases, general slopiness, etc… However, if you are using .006 inches of lift to determine when the valve begins opening, then you must also use .006 inches of lift to determine when the valve is closed. The intake valve duration will be the number of degrees between when the lobe had moved the lifter .006 up in its bore from its resting point on the cam to the point where the lifter reaches .006 inches from its resting position on the downhill side of the cam lobe.
In other words, you are measuring the opening events fine, but you need to not worry about the lobe height at the factory soecified degree, but you DO need to note where the lobe height equal .006.
In other words, keep rotating the cam until the dial reads .006 again and then note the degree ATDC that the lobe has reached that height again.
It sounds like the builder put in a cam with a little bit longer duration than stock.
Looking at the measurements you took, here is my ballpark guess as to the specs of the cam in your rebuilt motor (using .001 as the valve lift reference point. These numbers will change if .050 lift is used).
Spare engine specs (presumed stock cam)
Intake duration = 284 (19 btdc + 180 + 85 abdc)
intake lift = .251
Exhaust duration = 281 (50bbdc + 180 + 51 atdc)
exhaust lift = .251.5
valve overlap = 70 degrees (51 atdc exhaust closes + 19 btdc intake opens)
"Parts truck engine specs"
intake duration = 278 (19 + 180 + 79)
intake lift = .245
exhaust duration = 308 (50bbdc + 180 + 75abdc)
exhaust lift = .247
valve overlap = 82 degrees (63 atdc + 19 BTDC)
Now lets do the "spare engine" at .050 lift, since that is what lots of aftermakret cam companies use to give their cam specs:
intake duration = 221 (17 + 180 +24)
intake lift + .245
exhaust duration = 202 (15 bbdc + 180 + 7)
exhaust lift = .247
overlap = 23 (7+16)
Do those numbers make sense to you? I hope someone else comes along and checks my math on this. My brain hurts now.
PostPosted: Sat Jul 19, 2014 4:13 pm
CRAP! I did the .050 lift umbers wrong. Here they are done right.
"spare engine" at .050 lift:
intake duration = 221 degrees (17 + 180 + 24)
intake lift = .251
exhauist duration = 198 (13 + 180 + 6)
exhaust lift = .2505
overlap = 23 (17 + 6)
I think those are the right numbers...
PostPosted: Sat Jul 19, 2014 5:59 pm
I am amazed at how people can keep all these numbers straight in their mind! I just have a pea sized brain I guess.
I look on the cam card and find the "intake lobe center." If it says 108 degrees, I verify top dead center, install the degree wheel and rotate the engine until it reads maximum valve lift. Re-zero my dial indicator and then rotate to .050 on each side of zero on the dial indicator. Write down the readings, add them up and divide by 2. If that reading is 104 for example, that would be 4 degrees advanced. If it is off more than you want then you adjust from there.
I have found several timing sets that were stamped way off. I have had to move the timing chain whole tooth to get them close.
Hope that helps some.
Rick
PostPosted: Sun Jul 20, 2014 4:02 am
At this point I still stand on my observation ( and the observation of others ) that I have to know the method that was used to get the FSM numbers I am using to check the cam. Once I find out this and understand that method then I can go about checking the FSM numbers using the same method.
At this point I have not found this information and I am pretty close to throwing in the hat on finding this.
PostPosted: Sun Jul 20, 2014 6:03 am
This guy normally has reliable info. http://www.moparaction.com/tech/quest/CAM_PLANS.html
PostPosted: Sun Jul 20, 2014 10:58 am
This would seem to confirm. http://sbftech.com/index.php?topic=22953.10;wap2
PostPosted: Sun Jul 20, 2014 2:23 pm
Thanks for giving me these things to look over. Reed sent me a bunch of stuff via e-mail as well so I have my hands full to get caught up on all of this.
Users browsing this forum: Google [Bot] and 13 guests
