It is currently Tue May 19, 2026 12:45 pm
 Post subject: Upgrades Part 2
PostPosted: Thu Jun 19, 2014 7:09 pm
OK so now to talk about the braking system of the car. I wanted to add K-H discs to my car and keep the system manual. I was wondering if the 7 1/4" axle an be had with 10" drums or if the 8 3/4" axle is required for 10" drums. OK so another thing I wanted to do was add the HD suspension package S13 and HD shocks S25 to the car. I also wanted to reinforce the K-member and use polygraphite bushings wherever possible.
Recap:
Front Suspension
(1) Disc Brakes
(2) 0.87" Torsion Bars
(3) Polygraphite Bushings (less LCA pivot)
(4) K-member reinforcement
(5) HD Shock Absorbers
Rear Suspension...
(1) Bigger Rear Drums
(2) 6-Leaf Springs
(3) Sure-Grip
(4) HD Shock Absorbers
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Thu Jun 19, 2014 9:51 pm
Car Model: 1964 Dart GT
Sounds similar to my 64 Dart a few years back.
I had a 7.25 with 3.23, 6 leaf HD springs, 9" drums. All manual. Slant torsion bars. KH front disks up front with a polygraphite suspension rebuild. I added the 1.125" anti-sway bar up front. 7" wide 14" Cragers with radial T/A's all around. Car handles really well.
Since then I have upgraded the front brakes to SSBC front disks and put in a 8.75 rear with Moser axles so I can get the 4.5" bolt pattern. The SSBC bake kit uses the KH 4 piston calipers with their basic kit. They are great brakes. Also have rear discs now.
As far as 10" drums on the rear, I do not know. If I had to do it all over again, I would consider using a Dakota or Durango rear. They are an 8.25" rear with discs. Probably relatively cheap to do.
Good luck
PostPosted: Sun Jun 22, 2014 3:32 pm
if you can find a post-73 A-Body with spb (all drum car) it should have the 7 1/4 axle with the 10" drums. That's what my 76 dart sport has.
 Post subject: Careful...
PostPosted: Sun Jun 22, 2014 6:42 pm
Not all were like that, you could get 9" drums through those years too, until Jan 1976 build dates for certain...
PostPosted: Thu Jun 26, 2014 9:27 am
There's a '74 Dart with 10" drums and SBP for sale in TN right now for $250. Parts car?
http://slantsix.org/forum/viewtopic.php?t=55659
Escape Velocity Racing
 Post subject: Brakes
PostPosted: Tue Jul 22, 2014 4:36 pm
I am sure this info has been said many times, but what is the part number for the spindle/ 10 inch drums I need for the disc brake conversion for my 64 Dart GT. Thank you for your time.
PostPosted: Tue Jul 22, 2014 5:25 pm
The Sbp 1965-1972 Kelsey Hayes 4 piston type use a spindle specific to only those brakes. Usually these are sold used as a complete package.
PostPosted: Fri Jul 25, 2014 8:54 pm
I don't know every combination that Ma mopar put out over the years, but I always thought the 10" drum brake cars still had 9" drums in back. At least the two Darts I owned (a 70 & a 73) had 10" fronts & 9" rears.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Jul 25, 2014 10:14 pm
As far as I recall, my 1966 Barracuda had the 7 1/4 axle with the 10" drums. (The slant cars got the 9" version, the V8 got the 10".)
- Erik
