It is currently Fri Jun 05, 2026 4:25 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Aug 05, 2014 9:19 am
Before you try to break the nuts loose spray the crap out of them with PB Blaster for a couple days. You'll be glad you did.
PB Blaster is your friend.
....what he said
+1,2,3..?
1964 Dart GT
PostPosted: Tue Aug 05, 2014 10:30 am
As an FYI, it's the 2 end positions that are a concern... the iron conical washer in the centre position looks correct.
http://www.dutra.org/doug/draft-webpage ... ctions.htm
I'd spray and wire brush the exposed threads and then carefully try to unscrew the nuts... using 2 wrenches on the "double-nut" set, to get the top nut off first.
To be honest.. I would leave them alone IF they do not come-off easily with light effort. (if needed, go break some studs off a junk head, to get a "feel" for it)
If you can get them off, replace with the correct brass washers and locking nuts.
The contact surfaces should be smooth to allow for sliding action as the manifold heats & cools.
PostPosted: Tue Aug 05, 2014 12:09 pm
On the topic of brass nuts, it used to be common to use them on exhaust to manifold flange bolts. It is still a good practice to use them on any exhaust fastener that you want to remove intact some time later.
PostPosted: Tue Aug 05, 2014 1:41 pm
Just because it should be linked in this thread ...
DOC'S MANIFOLD INSTALLATION ARTICLE
Good call and I have read this ( printed and saved ) but I believe alot of this stuff was written quite a few years ago and of course things have changed, maybe a better way/step has come around. Thats why I ask sometimes what might seem obvious.
PostPosted: Tue Aug 05, 2014 1:43 pm
Im going to go out there in abit and try and loosen them, I bet they will come right off but will let you know either way how I make out. Thanks
PostPosted: Tue Aug 05, 2014 1:44 pm
Slantsixdan wrote a good post about the brass hardware, I cant seem to find it right now but I am hoping I will, covered all the part numbers to get the good stuff.
PostPosted: Tue Aug 05, 2014 2:50 pm
Heck that was easier than I thought, they just came right off, Image
I usually end up with the entire stud coming out like pictured to the right. I have quite a few of these from junkyard vehicles ( that I pull cause you never know who might need one ) and most of the time even putting them in a vise, soaking them down, waiting ect they just will not budge.
I was lucky to have a set that was ready to go though, I will clean up the mounting surfaces a bit over the weekend with at least a wire wheel and put this new hardware on.
Thanks again for the replies.
PostPosted: Wed Aug 06, 2014 3:24 am
Looking again at Docs manifold installation article it states............ The two acorn nuts go on the two top, outer end studs, with the coned shaped part of the nut fitting into the dished/conical part of the round brass washers..............
My brass washers appear identical on both sides, I have even laid a straightedge across the faces of the brass washers and I cant detect a dished/conical side?
I see and understand the dished conical steel washer that is in the center position but I see no such thing on these outer end brass washers.
Was this part of the instruction maybe intended for an earlier design brass washer?
These were pulled from slant exhaust manifolds all hydraulic 81 up manifolds.
PostPosted: Wed Aug 06, 2014 7:52 am
The brass washers, used on the end studs, are not conical... they are flat-faced, as described.
These washers should have an ID chamfer on one side, designed to accept the slotted "cone" on the lock nut. This special nut grips the stud, when the nut is tightened into the brass washer's angled ID.
PostPosted: Wed Aug 06, 2014 2:02 pm
Ok I can see that the nut goes in one side further than the other so I understand. Thanks
PostPosted: Sun Feb 08, 2015 11:56 pm
I have done a search but can't seem to find an answer , sorry about the old thread revival.
I am installing extractors/headers on my slant.
Do I still need to use the two brass washers and conical nuts on the two end studs ?
DRIVE IT,DON'T HIDE IT
PostPosted: Mon Feb 09, 2015 12:44 pm
6 Pack Dart
Not if they are 2 piece yes if they are 1 piece.
Richard
PostPosted: Wed Feb 11, 2015 1:17 am
Richard
Thanks Richard.
Would you class these as 2 or 1 piece ?
As you can see all six pipes go to one collector but the front 3 and rear 3 pipes are on 2 different mounting flanges , if you know what I mean , so I don't know if they could be considered a 1 or 2 piece unit.
I don't know what brand they are as they have no markings .
PostPosted: Wed Feb 11, 2015 4:17 pm
6 Pack Dart
Those are 2 piece, look at the head mount plates.The stock manifold is a 1 piece flange and needs to have the extra movement.
Richard
 Post subject: McMaster Carr
PostPosted: Sat Feb 14, 2015 6:36 pm
You can still by the correct brass nuts and the compression or "acorn" nuts at McMaster Carr.
All you need is the dished washers that go with the acorn nuts at each end of the manifold. If you PM me, I can find the correct ones for you and give you the McMaster item numbers and/or send you the correct ones. Read DD's install notes first, so you know how to install them. Also, if you are taking the manifolds loose (I agree with the posts that say if it ain't broke, don't bother) for some reason and replacing the gasket use Remflex gasket, it will not leak and provides great crush leeway for the manifolds alignment.
brian
https://tinyurl.com/yynpj4v2
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
